Hi all,
thanks everyone for this wonderful distro. I was hartbroken after Gnomes switch to version 3.x. Gnome 2.x is back- just better!!!
Anyways, I had a problem with audio on a Lenovo G40 which I solved by uninstalling and then reinstalling Pulseaudio. While uninstalling it also removed quite a bunch of packages (cannot remember which ones exactly, it was quite a list). Unfortunately after the reinstall the sound applet from the top panel is missing. I installed indicator sound and indicator sound gtk2, but that didn’t solve the problem. Also, I do not have a sound settings icon in the control panel.
I guess I just have to install some other packages. Any Idea which one?
Thank you very much in advance for your replies,
Cheers,
Christian
