I have Mate 21.04 (HH), 64 bit. 6July2021
When I activate zoom there are sound issues, - it doesn't work out of the box.
I don;t know how to fix this - I don't want to use MS but an forced to do so as my Mate PC have this problem. I do not understand the command line - never learned to use it.
Any help appreciated.
I am adding the output of another question on audio - see below - not sure if it helps?
........k-PC:~$ lshw -C sound
WARNING: you should run this program as super-user.
*-multimedia:0
description: Audio device
product: Wrestler HDMI Audio
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 1.1
bus info: pci@0000:00:01.1
version: 00
width: 32 bits
clock: 33MHz
capabilities: bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:30 memory:f0444000-f0447fff
*-multimedia:1
product: SBx00 Azalia (Intel HDA)
physical id: 14.2
bus info: pci@0000:00:14.2
version: 40
width: 64 bits
clock: 33MHz
configuration: driver=snd_hda_intel latency=32
resources: irq:16 memory:f0440000-f0443fff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
THANX
Rusty Beukes
