Steam does not install - missing libraries
When I try to install steam it gets so far then it tries to load some 386 libraries. Below is the message I get in the console:
Steam needs to install these additional packages:
libgl1-mesa-dri:i386, libgl1-mesa-glx:i386, libc6:i386
[sudo] password for robert:
.......................................................................................................................................................................................................................................................W: The repository 'cdrom://Ubuntu-MATE 16.04.1 LTS Xenial Xerus - Release powerpc (20160719) xenial Release' does not have a Release file.
E: Failed to fetch cdrom://Ubuntu-MATE 16.04.1 LTS Xenial Xerus - Release powerpc (20160719)/dists/xenial/main/binary-powerpc/Packages Please use apt-cdrom to allow APT to recognise this CD-ROM. 'apt-get update' cannot be used to add new CD-ROMs
E: Failed to fetch http://gb.ports.ubuntu.com/ubuntu-ports/dists/xenial/main/binary-i386/Packages 404 Not Found [IP: 2001:67c:1360:8001::22 80]
E: Failed to fetch http://gb.ports.ubuntu.com/ubuntu-ports/dists/xenial-updates/main/binary-i386/Packages 404 Not Found [IP: 2001:67c:1360:8001::22 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Reading package lists... Done
any idea where I can get these from and how to install them?
Ubuntu-MATE 16.04 on G5 PPC
E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/xenial-security/main/binary-i386/Packages 404 Not Found [IP: 2001:67c:1360:8001::22 80]
E: Failed to fetch http://gb.ports.ubuntu.com/ubuntu-ports/dists/xenial-backports/main/binary-i386/Packages 404 Not Found [IP: 2001:67c:1360:8001::22 80]
Othere missing links. Couldn’t add in first post as new user
Well, yes, Steam is an i386 app, for Intel & AMD CPUs…
So now way tro get Steam to work then I assume, unless I customise a later
mac?
Yes, try some later model with an Intel processor.
