@anon42388993 and @ouroumov,
Release 16.10 (Yakkety Yak) 64-bit
Kernel Linux 4.8.0-38-generic x86_64
MATE 1.16.0
Thank you both for your replies. I am running 16.10 through virtualbox at work (where the issue is) and 16.10 at home directly on hardware. Interestingly, the ~/.config/mate directory exists on my installation at home so, no issue there, just the virtualized install here at work. I’m not sure if it’s a fluke on the virtual install or if it has to do with another applet on my home system creating the mate directory before I installed sticky-notes. I’ll do some more digging as I have time. When I created the mate directory yesterday, the following showed up:
bcpalmer@bcpalmer-VirtualBox-Mate:~/.config/mate$ ll
total 36
drwxrwxr-x 2 bcpalmer bcpalmer 4096 Feb 20 12:48 ./
drwxr-xr-x 21 bcpalmer bcpalmer 4096 Feb 21 08:53 …/
-rw-rw-r-- 1 bcpalmer bcpalmer 24367 Feb 20 12:48 backgrounds.xml
-rw-rw-r-- 1 bcpalmer bcpalmer 208 Feb 21 08:56 stickynotes-applet.xml
Thanks again for your time.
I’m working to get much deeper in Linux world and really like Ubuntu Mate so far!
-BCPalmer
