Yesterday with an update of .xml files my quick notes disappeared, is there any way to recover them, I mean to be able to view them? I know that the path where they are located is ~/.config/mate/stickynotes-applet.xml. When I open the .xml file it does not contain what the notes had before the update.
Among the updates I found these from UM22.04 on a virtual machine that were the same ones I installed yesterday from my machine with UM21.10.
Of the updates that I highlight in bold is the one that possibly made my sticky notes disappear.
Preformatted textapport-gtk/jammy-updates,jammy-updates,jammy-security,jammy-security 2.20.11-0ubuntu82.1 all [actualizable desde: 2.20.11-0ubuntu82]
apport/jammy-updates,jammy-updates,jammy-security,jammy-security 2.20.11-0ubuntu82.1 all [actualizable desde: 2.20.11-0ubuntu82]
libldap-2.5-0/jammy-updates,jammy-security 2.5.11+dfsg-1~exp1ubuntu3.1 amd64 [actualizable desde: 2.5.11+dfsg-1~exp1ubuntu3]
libldap-common/jammy-updates,jammy-updates,jammy-security,jammy-security 2.5.11+dfsg-1~exp1ubuntu3.1 all [actualizable desde: 2.5.11+dfsg-1~exp1ubuntu3]
libpcre3/jammy-updates,jammy-security 2:8.39-13ubuntu0.22.04.1 amd64 [actualizable desde: 2:8.39-13build5]
libxml2/jammy-updates,jammy-security 2.9.13+dfsg-1ubuntu0.1 amd64 [actualizable desde: 2.9.13+dfsg-1build1]
python3-apport/jammy-updates,jammy-updates,jammy-security,jammy-security 2.20.11-0ubuntu82.1 all [actualizable desde: 2.20.11-0ubuntu82]
python3-problem-report/jammy-updates,jammy-updates,jammy-security,jammy-security 2.20.11-0ubuntu82.1 all [actualizable desde: 2.20.11-0ubuntu82]
wpasupplicant/jammy-updates 2:2.10-6ubuntu1 amd64 [actualizable desde: 2:2.10-6]
Thank you for the help.
