When I do for example ls in my mate terminal, it colorizes the files based on type.
How can I stop that?
If you just want to disable the coloured output of the ls command you have to comment out the follwing line in your .bashrc file.
~/.bashrc
75 # enable color support of ls and also add handy aliases
76 if [ -x /usr/bin/dircolors ]; then
77 test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)"
78 #alias ls='ls --color=auto'
79 #alias dir='dir --color=auto'
80 #alias vdir='vdir --color=auto'
81
82 alias grep='grep --color=auto'
83 alias fgrep='fgrep --color=auto'
84 alias egrep='egrep --color=auto'
85 fi
Line number 78.
Mickey
Thanks. I am going to comment out that whole section.
I thought I had stopped all of the “colorizing”, but it occured when I ran
cvlc -help
Does vlc have some built in function that colorizes output?
If you're looking to prevent colours in the terminal completely, consider changing the profile settings in Edit (menu bar) --> Profile Preferences:
From there you can pick a colour and drag it across to the other colours.
I can not find Profile settings?
Mickey
There was an unanticipated consequence of doing that.
Things like htop that rely on colors, did not show everything on screen.
I reverted back to xterm built in scheme. ![]()
