I have been looking for a way to not have my pc restart after a power failure. I can't find an options for that in the power settings, any ideas?
Quick web check seems to indicate it is controlled in Bios. Mine is under power management.
oh, ok, my bad. I should have figured that out
Even with my BIOS set to not restart after a power outage, my PC still does restart on occasion if the power outage is brief enough. YMMV.
