Hola.
Long term Ubuntu Maté user here, but I'm struggling with remote connections.
All I want to do is to connect from one Ubuntu machine to another.
I used to do this from Ubuntu machines to Windows Server using Remmina and it worked fine. But I've never figured out how to do it from Ubuntu to Ubuntu.
As I understand it, Ubuntu uses VNC, which has server and client components. I presume I just need to enable incoming connections or some such on each machine, but I can't find where to do that. I've googled around but can't find Desktop Sharing, Session Sharing or any such application. If I type vino-preferences, I get "command not found". So, where's the setting?
Oh, and I'm running Ubuntu Maté Desktop with a fresh install of 20.04 and the machines I need to connect to are also running Ubuntu Maté 20.04.
Thanks in advance,
Hal
