IBID raspberrypi Forum Moderator:
by mahjongg » Sun Feb 19, 2017 12:59 am
There is only one sd-card programmer you need, and that is the one in the downloads (installation help) section.
https://www.raspberrypi.org/documentati … n/noobs.md
The one you can find here:
https://www.sdcard.org/downloads/formatter_4/
Your card need to be no bigger than 32GB, you can format 64GB cards with this tool, but they will NOT be formatted in FAT32 formats, meaning that afterwards you need to format them again with another formatter, that reformats them to FAT32.
You still need the sdcard.org formatter, as this removes all superfluous partitions on the card that might be in the way, or using up space.
you also MUST use the overwrite format option.
Also consider your SD-card might be a fake, and try another one from a reliable source.
For much more boot problem help read the boot problem sticky in the beginners section.
