On Friday a change with Caja happened where I got stuck. How do I access internal devices not mounted in fstab at startup. I like 19.10, worth the challenging learning curve for me.
Any hard drive not specifically mounted by fstab can usually be found under /media. Go to File System, media, ray, <whatever_hard_drive>.
Only media ALREADY mounted appear in /media/ray, [had already found them] but the unmounted media still evade me. [5 more media]
Raymond Pitts
Then you need to be a LOT more specific about your problem.
Edit: I suggest that you post your fstab file and describe the drives that are not mounted. Fstab generally (by the way) isn't used to mount drives in /media.
