Hi there, I am pretty new with Raspberry Pis and have run into an issue when trying to use the "sudo apt-get upgrade" function.
For context I tried to install InfluxDB yesterday, following the instructions online - and i dont think it worked, or something happened with the install.
The problem I am encountering is that when I execute the command "sudo apt-get update" it comes up with an error message saying - "E: Malformed entry 1 in list file /etc/apt/sources.list.d/influxdb.list (Component)
E: The list of sources could not be read."
I have tried to replace the source in nano using "sudo more /etc/apt/sources.list" but it didnt make a difference.
When I use the command "sudo more /etc/apt/sources.list" I get this - deb Index of /raspbian bullseye main contrib non-free rpi
"# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb InfluxData - Package Repository $(lsb_release -cs) stable
I am at a lost end as I have no idea what to fix, any advice would be hugely appreciated.
Many thanks in advance!
