Does this mean that no updates will overwrite my thunar installation?
sudo apt-mark hold thunar
thunar set on hold.
thunar set on hold.
That is correct. Thunar will not be updated
See my comprehensive analysis on AskUbuntu:
The short answer - use apt pinning instead:
So my conclusion is the following:
apt-markis usable only if you install/remove/upgrade software only withapt-get, otherwise you should use pinning (i.e./etc/apt/preferences.d/), it is more reliable and straightforward.
Thanks for the info.
But this is confusing as to the format of the file needed. And I want to use geany as my editor.
Usually on my Ubuntu 16.04 LTS, I lock package versions with APT-pin functionality.
For example if I want to pin `meld` to version *1.5.3-1ubuntu1* I create the following pin-file:
cat <<EOF | sudo tee /etc/apt/preferences.d/pin-meld
Package: meld
Pin: version 1.5.3-1ubuntu1
Pin-Priority: 1337
EOF
I use such code snippet for automation - I do it from simple text terminal.
In your case you should determine current thunar version with apt-cache policy thunar (for example you got x.y.z-MubuntuN from it) and then fill /etc/apt/preferences.d/pin-thunar with info below:
Package: thunar
Pin: version x.y.z-MubuntuN
Pin-Priority: 1337
But if Thunar's version is greater than in your current distribution, then it would not upgrade until new Ubuntu version released.
I made a file called pin-thunar
Package: thunar
Pin: version 1.8.2-1~18.04
Pin-Priority: 1337
