Hi!
I can't use command:
sudo systemctl --user stop gvfs-metadata.service
because:
Failed to connect to bus: Operation not permitted
also:
= Failed to connect to bus: Operation not permitted
How can I fix that?
Hi!
because:
also:
How can I fix that?
Probably you do not need sudo
Instead try to use
thanks @ Norbert_X
