Since upgrading to Ubuntu 20.04, the programs that used to work with my DVB tuner no longer work.
I can't remember how it was set up. Hauppaugge have pretty good instructions, but I have no understanding of what they mean, but they all seemed to so what the instructions and video claimed here:
I've got as far as installing the firmware and rebooting my PC. At which point it says it is ready to "use by your Linux TV watching application" This is where I am stuck. I can't find a suitable program to play the freeview channels or even detect the device is there.
I've tried VLC which I always used to use and can no longer find any option to use a DVB device. Also tried Kaffeine and following instructions on how to get it working there, but when going to configure television, it has a greyed out model number of a completely different DVB stick and says there isn't currently one plugged in. I know mine is in and working as it has an orange and blue LED indicating that and it also has worked for around a year before I upgraded using VLC.
VLC never worked that well with it so I probably could do with trying a different program. I would prefer not to use the sort of program that opens up in full screen and makes it feel like you are using an entirely different operating system (kodi for example) as I find that a bit overwhelming.
Would much appreciate some advice.
