Hi, @nmboutin (neal)
You've asked:
Well, I think that one possibility is to check the /var/log/syslog
file after suspending and resuming. For instance, in my laptop computer that's also running Ubuntu MATE 22.04.3 ("Jammy Jellyfish"), if I click on the Power icon on the upper right corner of the Ubuntu MATE screen, to bring the "Power icon menu" (at least, that's what I call that menu) and then click on the "Suspend" option, the screen goes dark / black (as you also say) and the red physical LED that is on the physical power button of the laptop starts slowly blinking.
After a few minutes, if I click on the physical Power button again, the screen "wakes up", Ubuntu MATE also "wakes up" and the red physical power button stops blinking and stays on.
If I then go analyze the /var/log/syslog
file, I find the following lines related to the period when the laptop computer was in sleep (among many other lines):
Feb 9 20:46:30 mypc kernel: [ 2908.573061] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
Feb 9 20:46:30 mypc ModemManager[1183]: <info> [sleep-monitor-systemd] system is about to suspend
Feb 9 20:46:30 mypc NetworkManager[1080]: <info> [1707511590.1821] manager: sleep: sleep requested (sleeping: no enabled: yes)
Feb 9 20:46:30 mypc NetworkManager[1080]: <info> [1707511590.1824] device (wlo1): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Feb 9 20:46:30 mypc NetworkManager[1080]: <info> [1707511590.1838] manager: NetworkManager state is now ASLEEP
Feb 9 20:46:30 mypc NetworkManager[1080]: <info> [1707511590.1840] device (eno2): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Feb 9 20:46:30 mypc systemd[1]: Reached target Sleep.
Feb 9 20:46:30 mypc systemd[1]: Starting Record successful boot for GRUB...
Feb 9 20:46:30 mypc systemd[1]: Starting System Suspend...
Feb 9 20:46:30 mypc systemd[1]: grub-common.service: Deactivated successfully.
Feb 9 20:46:30 mypc systemd[1]: Finished Record successful boot for GRUB.
Feb 9 20:46:30 mypc systemd[1]: Starting GRUB failed boot detection...
Feb 9 20:46:30 mypc systemd[1]: grub-initrd-fallback.service: Deactivated successfully.
Feb 9 20:46:30 mypc systemd[1]: Finished GRUB failed boot detection.
Feb 9 20:46:30 mypc systemd-sleep[5184]: Entering sleep state 'suspend'...
Feb 9 20:46:30 mypc kernel: [ 2908.694953] PM: suspend entry (deep)
Feb 9 20:46:30 mypc kernel: [ 2908.717672] Filesystems sync: 0.022 seconds
Feb 9 20:46:44 mypc kernel: [ 2908.721299] Freezing user space processes ... (elapsed 0.001 seconds) done.
Feb 9 20:46:44 mypc kernel: [ 2908.722842] OOM killer disabled.
Feb 9 20:46:44 mypc kernel: [ 2908.722843] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Feb 9 20:46:44 mypc kernel: [ 2908.723975] printk: Suspending console(s) (use no_console_suspend to debug)
Feb 9 20:46:44 mypc kernel: [ 2910.996324] ACPI: EC: interrupt blocked
Feb 9 20:46:44 mypc kernel: [ 2911.094954] ACPI: PM: Preparing to enter system sleep state S3
Feb 9 20:46:44 mypc kernel: [ 2911.105756] ACPI: EC: event blocked
Feb 9 20:46:44 mypc kernel: [ 2911.105759] ACPI: EC: EC stopped
Feb 9 20:46:44 mypc kernel: [ 2911.105760] ACPI: PM: Saving platform NVS memory
Feb 9 20:46:44 mypc kernel: [ 2911.105777] Disabling non-boot CPUs ...
Feb 9 20:46:44 mypc kernel: [ 2911.108400] smpboot: CPU 1 is now offline
Feb 9 20:46:44 mypc kernel: [ 2911.112185] smpboot: CPU 2 is now offline
Feb 9 20:46:44 mypc kernel: [ 2911.115832] smpboot: CPU 3 is now offline
Feb 9 20:46:44 mypc kernel: [ 2911.119407] smpboot: CPU 4 is now offline
And here are the lines apparently from when the computer resumed from suspension:
Feb 9 20:46:44 mypc kernel: [ 2911.146498] ACPI: EC: EC started
Feb 9 20:46:44 mypc kernel: [ 2911.146498] ACPI: PM: Restoring platform NVS memory
Feb 9 20:46:44 mypc kernel: [ 2911.147395] Enabling non-boot CPUs ...
Feb 9 20:46:44 mypc kernel: [ 2911.147434] x86: Booting SMP configuration:
Feb 9 20:46:44 mypc kernel: [ 2911.147435] smpboot: Booting Node 0 Processor 1 APIC 0x2
Feb 9 20:46:44 mypc kernel: [ 2911.150173] CPU1 is up
Feb 9 20:46:44 mypc kernel: [ 2911.150194] smpboot: Booting Node 0 Processor 2 APIC 0x4
Feb 9 20:46:44 mypc kernel: [ 2911.152012] CPU2 is up
Feb 9 20:46:44 mypc kernel: [ 2911.152030] smpboot: Booting Node 0 Processor 3 APIC 0x6
Feb 9 20:46:44 mypc kernel: [ 2911.153824] CPU3 is up
Feb 9 20:46:44 mypc kernel: [ 2911.153842] smpboot: Booting Node 0 Processor 4 APIC 0x8
Feb 9 20:46:44 mypc kernel: [ 2911.155677] CPU4 is up
Feb 9 20:46:44 mypc kernel: [ 2911.167085] ACPI: PM: Waking up from system sleep state S3
Feb 9 20:46:44 mypc kernel: [ 2911.174147] ACPI: EC: interrupt unblocked
Feb 9 20:46:44 mypc kernel: [ 2912.303221] ACPI: EC: event unblocked
Feb 9 20:46:44 mypc kernel: [ 2912.791539] OOM killer enabled.
Feb 9 20:46:44 mypc kernel: [ 2912.791543] Restarting tasks ...
Feb 9 20:46:44 mypc systemd-resolved[882]: Clock change detected. Flushing caches.
Feb 9 20:46:44 mypc rtkit-daemon[1686]: The canary thread is apparently starving. Taking action.
Feb 9 20:46:44 mypc rtkit-daemon[1686]: Demoting known real-time threads.
Feb 9 20:46:44 mypc kernel: [ 2912.804072] PM: suspend exit
Feb 9 20:46:44 mypc systemd-sleep[5184]: System returned from sleep state.
Feb 9 20:46:44 mypc dbus-daemon[2029]: [session uid=1000 pid=2029] Successfully activated service 'org.freedesktop.Notifications'
Feb 9 20:46:44 mypc systemd[1]: systemd-suspend.service: Deactivated successfully.
Feb 9 20:46:44 mypc systemd[1]: Finished System Suspend.
Feb 9 20:46:44 mypc systemd[1]: Stopped target Sleep.
Feb 9 20:46:44 mypc systemd[1]: Reached target Suspend.
Feb 9 20:46:44 mypc systemd[1]: Stopped target Suspend.
Feb 9 20:46:44 mypc ModemManager[1183]: <info> [sleep-monitor-systemd] system is resuming
Feb 9 20:46:44 mypc NetworkManager[1080]: <info> [1707511604.7732] manager: sleep: wake requested (sleeping: yes enabled: yes)
I hope this helps
