I want to run WindowMaker on Ubuntu MATE on the R Pi 3, and installed it following the instructions here:
But I can't seem to switch window managers: I don't get any of the options in the article (I created another user account to to enable the Log out / Log in option).
If I run wmaker from the Terminal, I get: 'usr/lib/WindowMaker/wmaker (Startup(startup.c:636): fatal : it seems that there is already a widow manager running'.
So WindowMaker seems to be installed correctly. So I went to kill LightGDM
(sudo service lightgdm stop), which I assumed would take me to a command
line, but all I got was a blinking white vertical bar, top left and no
ability to input text.
Any ideas? How do you switch between Desktop Managers in MATE?
What for? You can logout/login without creating new user account.
I usually switch between them without creating a new account. Reboot your pc and try to select WindowMaker again If that didn't help, edit your ~/.xinitrc to load Window Maker using the line exec /usr/local/bin/wmaker .
That's just the problem: when I reboot, I don't get any options for choosing WindowMaker, only the option to switch user accounts... can we insert images into replies so you can see what I'm getting?
