I was just checking to see if I got the upgrade notification on Win 7 since I havent booted into 7 since fall of last year. So I fired it up and found that it’s partition doesnt have enough space for the updates it needs, I had been wanting to nuke and pave this laptop for awhile now either putting ubuntuMate as the base OS and running 7 in a VM or Just giving ubuntuMate the majority of the hard drive. Nearly all of my data I care to keep is already “on the cloud” or external hard drive just a usb drive away this mean my set up options are nearly limitless. So here lies a couple of questions.
If I go with UM as the base OS and 7 in a VM will I run into problems with the licensing of 7 not being on bare metal. I dont care if it is “legal”. Just whether it will work. Because I plan on upgrading it to 10.
With the above option is it possible to just delete the ntfs partitions, resize the swap and UM partitions and then install 7 in the VM? This way I dont loose all my customizations?
In order do this in separate partitions I will need to resize my 7 partition to allow more space to do the upgrade which could end up borking my UM. So I will have to basically start everything over from scratch right?
Give me some suggestions people.
