Greetings All,
Starting on the 7/28/23 and there after, I have been having crashing issue with my computer after it does updates. What appears to be happening as the prompts flash by is I am getting "Snap loading errors" which shortly drops me into a system prompt. I was able to restart under an older GRUBs menu option to boot my system back up, and then I used Timeshift to recover before an upgrade which temporarily solves my issue. I found if I use "sudo apt-get update && sudo apt-get upgrade" this will not cause a crash. The issue seems to be after a snap is upgrade, but I am not sure how to check that. I sure that I will be asked for a log file entry, but if you can let me know which one, I will be more than happy to supply it. I have also supply system information to get us stated. Thanks in advance.
mike@derSchlaefer:~$ sudo inxi -Famxz
[sudo] password for mike:
System:
Kernel: 5.15.0-76-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.15.0-76-generic
root=UUID=b386fa7b-dbf3-4aec-a3a2-1c39aedc8d93 ro intel_iommu=off
amd_iommu=off quiet splash vt.handoff=7
Desktop: MATE 1.26.0 info: mate-panel wm: marco 1.26.0 dm: LightDM 1.30.0
Distro: Ubuntu 22.04.3 LTS (Jammy Jellyfish)
Machine:
Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
Mobo: ASUSTeK model: ROG STRIX Z590-E GAMING WIFI v: Rev 1.xx
serial: UEFI: American Megatrends v: 0605 date: 03/11/2021
Memory:
RAM: total: 31.18 GiB used: 2.77 GiB (8.9%)
Array-1: capacity: 64 GiB slots: 4 EC: None max-module-size: 16 GiB
note: est.
Device-1: Controller0-ChannelA-DIMM0 size: No Module Installed
Device-2: Controller0-ChannelA-DIMM1 size: 16 GiB speed: spec: 2667 MT/s
actual: 2666 MT/s type: DDR4 detail: synchronous bus-width: 64 bits
total: 64 bits manufacturer: Crucial Technology
part-no: BL16G32C16U4B.16FE serial:
Device-3: Controller0-ChannelB-DIMM0 size: No Module Installed
Device-4: Controller0-ChannelB-DIMM1 size: 16 GiB speed: spec: 2667 MT/s
CPU:
Info: model: 11th Gen Intel Core i9-11900K socket: LGA1200 bits: 64
type: MT MCP arch: Rocket Lake family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x57
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/5100:5300
base/boost: 3465/12000 scaling: driver: intel_pstate governor: powersave
volts: 0.9 V ext-clock: 100 MHz cores: 1: 801 2: 801 3: 801 4: 800 5: 801
6: 801 7: 801 8: 800 9: 800 10: 801 11: 801 12: 801 13: 801 14: 801
15: 800 16: 800 bogomips: 112128
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Vulnerabilities:
Type: itlb_multihit status: Not affected
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
Type: retbleed mitigation: Enhanced IBRS
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: lanes: 16 ports: active: DP-1,HDMI-A-1
empty: DP-2,DP-3,DVI-D-1 bus-ID: 01:00.0 chip-ID: 1002:67df
class-ID: 0300
Device-2: EMEET HD Webcam C960 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-10.1:6 chip-ID: 328f:003f class-ID: 0102 serial:
Display: server: X.Org v: 1.21.1.4 compositor: marco v: 1.26.0 driver: X:
loaded: amdgpu,ati unloaded: fbdev,modesetting,vesa gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: DisplayPort-0 mapped: DP-1 pos: primary,left
model: Sceptre F24 serial: built: 2021 res: 1920x1080 hz: 60
dpi: 94 gamma: 1.2 size: 520x320mm (20.5x12.6") diag: 611mm (24.1")
ratio: 16:10 modes: max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-0 mapped: HDMI-A-1 pos: right model: Sceptre F24
serial: built: 2021 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 520x320mm (20.5x12.6") diag: 611mm (24.1") ratio: 16:10 modes:
OpenGL: renderer: AMD Radeon RX 590 Series (polaris10 LLVM 15.0.7 DRM
3.42 5.15.0-76-generic)
v: 4.6 Mesa 22.2.5-0ubuntu0.1~22.04.3 direct render: Yes
Audio:
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:43c8 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0
class-ID: 0403
Device-3: EMEET HD Webcam C960 type: USB driver: snd-usb-audio,uvcvideo
Device-4: ASUSTek USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-14:7 chip-ID: 0b05:1996
class-ID: 0300
Sound Server-1: ALSA v: k5.15.0-76-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0f:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp15s0 state: down mac:
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 10:00.0
chip-ID: 8086:15f3 class-ID: 0200
IF: enp16s0 state: down mac:
Device-3: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 11:00.0
chip-ID: 8086:2725 class-ID: 0280
IF: wlp17s0 state: up mac:
Bluetooth:
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-2:2 chip-ID: 8087:0032 class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 0 state: up address:
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: peripheral accept
service-classes: rendering, capturing, object transfer, audio, telephony
RAID:
Hardware-1: Intel Device driver: ahci v: 3.0 port: 7020 bus-ID: 00:17.0
chip-ID: 8086:43d6 rev: N/A class-ID: 0104
Hardware-2: HighPoint Device driver: hptnvme v: 1.5.1 port: 5000
bus-ID: 0a:00.0 chip-ID: 1103:7103 rev: N/A class-ID: 0104
Drives:
Local Storage: total: 1.82 TiB used: 444.28 GiB (23.8%)
SMART Message: Required tool smartctl not installed. Check --recommends
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: rev: 033
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
Partition:
ID-1: / raw-size: 930.94 GiB size: 915.25 GiB (98.31%)
used: 304.4 GiB (33.3%) fs: ext4 block-size: 4096 B dev: /dev/hptblock0n0p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 6.1 MiB (1.2%) fs: vfat block-size: 512 B dev: /dev/hptblock0n0p1
maj-min: 259:1
Swap:
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Sensors:
System Temperatures: cpu: 27.8 C mobo: N/A gpu: amdgpu temp: 47.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 2
Info:
Processes: 422 Uptime: 11m wakeups: 0 Init: systemd v: 249 runlevel: 5
tool: systemctl Compilers: gcc: 11.4.0 alt: 11/12 Packages: 3066 apt: 3036
lib: 1579 flatpak: 0 snap: 30 Shell: Sudo (sudo) v: 1.9.9 default: Bash
v: 5.1.16 running-in: mate-terminal inxi: 3.3.13
