Hello
All, I’m running Ubuntu Mate 16.04 LTS Version 4.4.0-22-generic on
a HP Pavillion Note Book . Laptop has a i5-6200U 2.30 GHz CPU with
6MB of RAM. Software other than those that are prepackaged are:
4K Video Downloader (for downloading YouTube videos to HardDrive)
Terminator (Terminal Alternative)
Buddi (Personal Budget Manager)
Master PDF (Editor for PDF (Personal File Documents)
Kazam (Desktop Recording)
Last Pass for FireFox (Password Manager for websites)
Gnote ( Sticky Notes)
BleachBit ( System and File Cleaner)
The problem I’m experiencing is that the system complely freezes where I have to use the cntrl-alt-backspace command to get back into a
working system. Any advice or suggesstions will be greatly
appreciated.
Yes, I have update
my system through the System Updater in the drop down menu. I’ve
also used my command terminal using sudo apt-get update & upgrade
commands. To unfreeze it I use the ctrl+alt-backspace command and it
will come back but I lose all my previous data. The screen-shot
shown in the email you sent me doesn’t show the option in the
upper right corner to update automatically. Here’s a screen-shot
of my Welcome Screen. And yes I've ran "Fixes" in the Software Boutique.
