After I purged the arctica-greeter and installed slick-greeter I got this problem. My system is configured to never go to sleep, that is been ignored and suspend when is not IDLE. And happens once after boot.
The workaround is to disable suspend the sleep feature:
https://wiki.debian.org/Suspend#Disable_suspend_and_hibernation
But I still want to be able to suspend manually.
Syslog:
Sep 3 15:05:01 i5 CRON[8849]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Sep 3 15:06:30 i5 ModemManager[1729]: <info> [sleep-monitor-systemd] system is about to suspend
Sep 3 15:06:30 i5 NetworkManager[1566]: <info> [1693764390.7533] manager: sleep: sleep requested (sleeping: no enabled: yes)
Sep 3 15:06:30 i5 NetworkManager[1566]: <info> [1693764390.7534] manager: NetworkManager state is now ASLEEP
Sep 3 15:06:30 i5 NetworkManager[1566]: <info> [1693764390.7538] device (eno1): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Sep 3 15:06:30 i5 dbus-daemon[1565]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.10' (uid=0 pid=1566 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined")
Sep 3 15:06:30 i5 kernel: [ 1690.629707] audit: type=1107 audit(1693764390.757:116): pid=1565 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_signal" bus="system" path="/org/freedesktop/GeoClue2/Manager" interface="org.freedesktop.DBus.Properties" member="PropertiesChanged" name=":1.121" mask="receive" pid=3216 label="/usr/bin/redshift" peer_pid=3227 peer_label="unconfined"
Sep 3 15:06:30 i5 kernel: [ 1690.629707] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Sep 3 15:06:30 i5 systemd[1]: Starting Network Manager Script Dispatcher Service...
Sep 3 15:06:30 i5 dbus-daemon[1565]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Sep 3 15:06:30 i5 systemd[1]: Started Network Manager Script Dispatcher Service.
Sep 3 15:06:30 i5 NetworkManager[1566]: <info> [1693764390.8527] device (eno1): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Sep 3 15:06:30 i5 avahi-daemon[1562]: Withdrawing address record for 2804:14c:b6:9601::1f3a on eno1.
Sep 3 15:06:30 i5 avahi-daemon[1562]: Withdrawing address record for 2804:14c:b6:9601:bad4:3527:8a3:64ec on eno1.
Sep 3 15:06:30 i5 avahi-daemon[1562]: Withdrawing address record for 2804:14c:b6:9601:10cf:5875:abfe:2ef7 on eno1.
Sep 3 15:06:30 i5 avahi-daemon[1562]: Leaving mDNS multicast group on interface eno1.IPv6 with address 2804:14c:b6:9601:10cf:5875:abfe:2ef7.
Sep 3 15:06:30 i5 avahi-daemon[1562]: Joining mDNS multicast group on interface eno1.IPv6 with address fe80::a338:da0a:7c02:12c8.
Sep 3 15:06:30 i5 avahi-daemon[1562]: Registering new address record for fe80::a338:da0a:7c02:12c8 on eno1.*.
Sep 3 15:06:30 i5 NetworkManager[1566]: <info> [1693764390.8547] dhcp4 (eno1): canceled DHCP transaction
Sep 3 15:06:30 i5 NetworkManager[1566]: <info> [1693764390.8547] dhcp4 (eno1): activation: beginning transaction (timeout in 45 seconds)
Sep 3 15:06:30 i5 avahi-daemon[1562]: Withdrawing address record for fe80::a338:da0a:7c02:12c8 on eno1.
Sep 3 15:06:30 i5 NetworkManager[1566]: <info> [1693764390.8547] dhcp4 (eno1): state changed no lease
Sep 3 15:06:30 i5 avahi-daemon[1562]: Leaving mDNS multicast group on interface eno1.IPv6 with address fe80::a338:da0a:7c02:12c8.
Sep 3 15:06:30 i5 NetworkManager[1566]: <info> [1693764390.8550] dhcp6 (eno1): canceled DHCP transaction
Sep 3 15:06:30 i5 avahi-daemon[1562]: Interface eno1.IPv6 no longer relevant for mDNS.
Sep 3 15:06:30 i5 NetworkManager[1566]: <info> [1693764390.8550] dhcp6 (eno1): activation: beginning transaction (timeout in 45 seconds)
Sep 3 15:06:30 i5 NetworkManager[1566]: <info> [1693764390.8550] dhcp6 (eno1): state changed no lease
Sep 3 15:06:30 i5 systemd-resolved[1451]: Using degraded feature set UDP instead of UDP+EDNS0 for DNS server 2804:14d:1:0:181:213:132:3.
Sep 3 15:06:30 i5 systemd-resolved[1451]: Using degraded feature set UDP instead of UDP+EDNS0 for DNS server 181.213.132.2.
Sep 3 15:06:30 i5 avahi-daemon[1562]: Withdrawing address record for 192.168.0.48 on eno1.
Sep 3 15:06:30 i5 avahi-daemon[1562]: Leaving mDNS multicast group on interface eno1.IPv4 with address 192.168.0.48.
Sep 3 15:06:30 i5 avahi-daemon[1562]: Interface eno1.IPv4 no longer relevant for mDNS.
Sep 3 15:06:30 i5 systemd-resolved[1451]: eno1: Bus client reset search domain list.
Sep 3 15:06:30 i5 dnsmasq[1998]: reading /etc/resolv.conf
Sep 3 15:06:30 i5 dnsmasq[1998]: using nameserver 127.0.0.53#53
Sep 3 15:06:30 i5 systemd-resolved[1451]: eno1: Bus client set default route setting: no
Sep 3 15:06:30 i5 systemd-resolved[1451]: eno1: Bus client reset DNS server list.
Sep 3 15:06:30 i5 NetworkManager[1566]: <info> [1693764390.8963] device (eno1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Sep 3 15:06:30 i5 kernel: [ 1690.866282] e1000e 0000:00:19.0 eno1: NIC Link is Down
Sep 3 15:06:31 i5 systemd[1]: Reached target Sleep.
Sep 3 15:06:31 i5 systemd[1]: Starting Record successful boot for GRUB...
Sep 3 15:06:31 i5 systemd[1]: Starting System Suspend...
Sep 3 15:06:31 i5 systemd-sleep[9048]: Entering sleep state 'suspend'...
Sep 3 15:06:31 i5 kernel: [ 1690.914251] PM: suspend entry (deep)
Sep 3 15:06:31 i5 systemd[1]: grub-common.service: Deactivated successfully.
Sep 3 15:06:31 i5 systemd[1]: Finished Record successful boot for GRUB.
Sep 3 15:06:31 i5 systemd[1]: Starting GRUB failed boot detection...
Sep 3 15:06:31 i5 systemd[1]: grub-initrd-fallback.service: Deactivated successfully.
Sep 3 15:06:31 i5 systemd[1]: Finished GRUB failed boot detection.
Sep 3 15:06:31 i5 kernel: [ 1691.128895] Filesystems sync: 0.214 seconds
Sep 3 15:06:37 i5 kernel: [ 1691.625936] Freezing user space processes ... (elapsed 0.001 seconds) done.
Sep 3 15:06:37 i5 kernel: [ 1691.627813] OOM killer disabled.
Sep 3 15:06:37 i5 kernel: [ 1691.627814] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Sep 3 15:06:37 i5 kernel: [ 1691.629090] printk: Suspending console(s) (use no_console_suspend to debug)
Sep 3 15:06:37 i5 kernel: [ 1691.631260] parport_pc 00:07: disabled
Sep 3 15:06:37 i5 kernel: [ 1691.631494] serial 00:06: disabled
Sep 3 15:06:37 i5 kernel: [ 1691.631700] serial 00:05: disabled
Sep 3 15:06:37 i5 kernel: [ 1691.631926] e1000e: EEE TX LPI TIMER: 00000011
Sep 3 15:06:37 i5 kernel: [ 1691.651746] sd 0:0:1:0: [sdb] Synchronizing SCSI cache
Sep 3 15:06:37 i5 kernel: [ 1691.652058] sd 0:0:1:0: [sdb] Stopping disk
Sep 3 15:06:37 i5 kernel: [ 1691.655688] sd 1:0:1:0: [sdc] Synchronizing SCSI cache
Sep 3 15:06:37 i5 kernel: [ 1691.655755] sd 2:0:0:0: [sdd] Synchronizing SCSI cache
Sep 3 15:06:37 i5 kernel: [ 1691.655758] sd 0:0:0:0: [sda] Synchronizing SCSI cache
Sep 3 15:06:37 i5 kernel: [ 1691.655878] sd 1:0:1:0: [sdc] Stopping disk
Sep 3 15:06:37 i5 kernel: [ 1691.656104] sd 2:0:0:0: [sdd] Stopping disk
Sep 3 15:06:37 i5 kernel: [ 1692.236825] sd 0:0:0:0: [sda] Stopping disk
Sep 3 15:06:37 i5 kernel: [ 1692.740337] ACPI: PM: Preparing to enter system sleep state S3
Sep 3 15:06:37 i5 kernel: [ 1692.740927] ACPI: PM: Saving platform NVS memory
Sep 3 15:06:37 i5 kernel: [ 1692.740946] Disabling non-boot CPUs ...
Sep 3 15:06:37 i5 kernel: [ 1692.742590] smpboot: CPU 1 is now offline
Sep 3 15:06:37 i5 kernel: [ 1692.745662] smpboot: CPU 2 is now offline
Sep 3 15:06:37 i5 kernel: [ 1692.747900] smpboot: CPU 3 is now offline
Sep 3 15:06:37 i5 kernel: [ 1692.750091] smpboot: CPU 4 is now offline
Sep 3 15:06:37 i5 kernel: [ 1692.751944] smpboot: CPU 5 is now offline
Sep 3 15:06:37 i5 kernel: [ 1692.754152] smpboot: CPU 6 is now offline
Sep 3 15:06:37 i5 kernel: [ 1692.756003] smpboot: CPU 7 is now offline
Sep 3 15:06:37 i5 kernel: [ 1692.758083] ACPI: PM: Low-level resume complete
Sep 3 15:06:37 i5 kernel: [ 1692.758103] ACPI: PM: Restoring platform NVS memory
Sep 3 15:06:37 i5 kernel: [ 1692.758433] Enabling non-boot CPUs ...
Sep 3 15:06:37 i5 kernel: [ 1692.758478] x86: Booting SMP configuration:
Sep 3 15:06:37 i5 kernel: [ 1692.758479] smpboot: Booting Node 0 Processor 1 APIC 0x2
Sep 3 15:06:37 i5 kernel: [ 1692.761917] CPU1 is up
Sep 3 15:06:37 i5 kernel: [ 1692.761957] smpboot: Booting Node 0 Processor 2 APIC 0x4
Sep 3 15:06:37 i5 kernel: [ 1692.765408] CPU2 is up
Sep 3 15:06:37 i5 kernel: [ 1692.765442] smpboot: Booting Node 0 Processor 3 APIC 0x6
Sep 3 15:06:37 i5 kernel: [ 1692.769116] CPU3 is up
Sep 3 15:06:37 i5 kernel: [ 1692.769150] smpboot: Booting Node 0 Processor 4 APIC 0x1
Sep 3 15:06:37 i5 kernel: [ 1692.772042] CPU4 is up
Sep 3 15:06:37 i5 kernel: [ 1692.772068] smpboot: Booting Node 0 Processor 5 APIC 0x3
Sep 3 15:06:37 i5 kernel: [ 1692.774871] CPU5 is up
Sep 3 15:06:37 i5 kernel: [ 1692.774900] smpboot: Booting Node 0 Processor 6 APIC 0x5
Sep 3 15:06:37 i5 kernel: [ 1692.777754] CPU6 is up
Sep 3 15:06:37 i5 kernel: [ 1692.777778] smpboot: Booting Node 0 Processor 7 APIC 0x7
Sep 3 15:06:37 i5 kernel: [ 1692.780662] CPU7 is up
Sep 3 15:06:37 i5 kernel: [ 1692.783287] ACPI: PM: Waking up from system sleep state S3
Sep 3 15:06:37 i5 kernel: [ 1692.826034] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN1.DRV1._GTF.DSSP], AE_NOT_FOUND (20210730/psargs-330)
Sep 3 15:06:37 i5 kernel: [ 1692.826045]
Sep 3 15:06:37 i5 kernel: [ 1692.826047] No Local Variables are initialized for Method [_GTF]
Sep 3 15:06:37 i5 kernel: [ 1692.826048]
Sep 3 15:06:37 i5 kernel: [ 1692.826049] No Arguments are initialized for method [_GTF]
Sep 3 15:06:37 i5 kernel: [ 1692.826050]
Sep 3 15:06:37 i5 kernel: [ 1692.826052] ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN1.DRV1._GTF due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Sep 3 15:06:37 i5 kernel: [ 1692.826255] sd 0:0:0:0: [sda] Starting disk
Sep 3 15:06:37 i5 kernel: [ 1692.826256] sd 0:0:1:0: [sdb] Starting disk
Sep 3 15:06:37 i5 kernel: [ 1692.826258] sd 1:0:1:0: [sdc] Starting disk
Sep 3 15:06:37 i5 kernel: [ 1692.826261] sd 2:0:0:0: [sdd] Starting disk
Sep 3 15:06:37 i5 kernel: [ 1692.826457] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN0.DRV0._GTF.DSSP], AE_NOT_FOUND (20210730/psargs-330)
Sep 3 15:06:37 i5 kernel: [ 1692.826465]
Sep 3 15:06:37 i5 kernel: [ 1692.826467] No Local Variables are initialized for Method [_GTF]
Sep 3 15:06:37 i5 kernel: [ 1692.826468]
Sep 3 15:06:37 i5 kernel: [ 1692.826469] No Arguments are initialized for method [_GTF]
Sep 3 15:06:37 i5 kernel: [ 1692.826470]
Sep 3 15:06:37 i5 kernel: [ 1692.826472] ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN0.DRV0._GTF due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Sep 3 15:06:37 i5 kernel: [ 1692.826510] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT1.CHN0.DRV0._GTF.DSSP], AE_NOT_FOUND (20210730/psargs-330)
Sep 3 15:06:37 i5 kernel: [ 1692.826518]
Sep 3 15:06:37 i5 kernel: [ 1692.826519] No Local Variables are initialized for Method [_GTF]
Sep 3 15:06:37 i5 kernel: [ 1692.826520]
Sep 3 15:06:37 i5 kernel: [ 1692.826521] No Arguments are initialized for method [_GTF]
Sep 3 15:06:37 i5 kernel: [ 1692.826522]
Sep 3 15:06:37 i5 kernel: [ 1692.826524] ACPI Error: Aborting method \_SB.PCI0.SAT1.CHN0.DRV0._GTF due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Sep 3 15:06:37 i5 kernel: [ 1692.826565] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN0.DRV1._GTF.DSSP], AE_NOT_FOUND (20210730/psargs-330)
Sep 3 15:06:37 i5 kernel: [ 1692.826571]
Sep 3 15:06:37 i5 kernel: [ 1692.826572] No Local Variables are initialized for Method [_GTF]
Sep 3 15:06:37 i5 kernel: [ 1692.826573]
Sep 3 15:06:37 i5 kernel: [ 1692.826574] No Arguments are initialized for method [_GTF]
Sep 3 15:06:37 i5 kernel: [ 1692.826575]
Sep 3 15:06:37 i5 kernel: [ 1692.826577] ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN0.DRV1._GTF due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Sep 3 15:06:37 i5 kernel: [ 1692.827265] serial 00:05: activated
Sep 3 15:06:37 i5 kernel: [ 1692.828017] serial 00:06: activated
Sep 3 15:06:37 i5 kernel: [ 1692.828656] parport_pc 00:07: activated
Sep 3 15:06:37 i5 kernel: [ 1692.988423] usb 4-4: Disable of device-initiated U1 failed.
Sep 3 15:06:37 i5 kernel: [ 1692.991910] usb 4-4: Disable of device-initiated U2 failed.
Sep 3 15:06:37 i5 kernel: [ 1693.117780] usb 4-4: reset SuperSpeed USB device number 2 using xhci_hcd
Sep 3 15:06:37 i5 kernel: [ 1693.865534] ata4: failed to resume link (SControl 30)
Sep 3 15:06:37 i5 kernel: [ 1693.865536] ata2.00: failed to resume link (SControl 30)
Sep 3 15:06:37 i5 kernel: [ 1693.876528] ata4: SATA link down (SStatus 4 SControl 30)
Sep 3 15:06:37 i5 kernel: [ 1694.469604] OOM killer enabled.
Sep 3 15:06:37 i5 acpid: client 1788[0:0] has disconnected
Sep 3 15:06:37 i5 systemd-resolved[1451]: Clock change detected. Flushing caches.
Sep 3 15:06:37 i5 systemd-sleep[9048]: System returned from sleep state.
Sep 3 15:06:37 i5 dbus-daemon[2215]: [session uid=115 pid=2211] Activating service name='org.freedesktop.Notifications' requested by ':1.7' (uid=115 pid=2356 comm="nm-applet " label="unconfined")
Sep 3 15:06:37 i5 kernel: [ 1694.469606] Restarting tasks ... done.
Sep 3 15:06:37 i5 kernel: [ 1694.473462] PM: suspend exit
Sep 3 15:06:38 i5 dbus-daemon[2215]: [session uid=115 pid=2211] Successfully activated service 'org.freedesktop.Notifications'
Sep 3 15:06:38 i5 acpid: client connected from 1788[0:0]
Sep 3 15:06:38 i5 acpid: 1 client rule loaded
Sep 3 15:06:38 i5 rtkit-daemon[2035]: Supervising 6 threads of 2 processes of 2 users.
Sep 3 15:06:38 i5 kernel: [ 1694.663406] NVRM: Xid (PCI:0000:02:00): 31, pid=1789, name=Xorg, Ch 0000000a, intr 10000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_0 faulted @ 0x0_a7ba0000. Fault is of type FAULT_PDE ACCESS_TYPE_WRITE
Sep 3 15:06:38 i5 rtkit-daemon[2035]: Successfully made thread 9370 of process 2021 owned by '1000' RT at priority 5.
Sep 3 15:06:38 i5 rtkit-daemon[2035]: Supervising 7 threads of 2 processes of 2 users.
Sep 3 15:06:38 i5 kernel: [ 1694.686397] NVRM: Xid (PCI:0000:02:00): 69, pid=1789, name=Xorg, Class Error: ChId 000a, Class 0000902d, Offset 00000250, Data 000055f2, ErrorCode 0000000c
Sep 3 15:06:38 i5 kernel: [ 1695.125632] ata2.00: SATA link down (SStatus 4 SControl 30)
Sep 3 15:06:38 i5 kernel: [ 1695.125644] ata2.01: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Sep 3 15:06:38 i5 kernel: [ 1695.157876] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN1.DRV1._GTF.DSSP], AE_NOT_FOUND (20210730/psargs-330)
Sep 3 15:06:38 i5 kernel: [ 1695.157890]
Sep 3 15:06:38 i5 kernel: [ 1695.157892] No Local Variables are initialized for Method [_GTF]
Sep 3 15:06:38 i5 kernel: [ 1695.157893]
Sep 3 15:06:38 i5 kernel: [ 1695.157894] No Arguments are initialized for method [_GTF]
Sep 3 15:06:38 i5 kernel: [ 1695.157895]
Sep 3 15:06:38 i5 kernel: [ 1695.157897] ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN1.DRV1._GTF due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Sep 3 15:06:38 i5 kernel: [ 1695.177942] ata2.01: configured for UDMA/133
Sep 3 15:06:39 i5 kernel: [ 1696.025674] ata1.00: SATA link up 6.0 Gbps (SStatus 133 SControl 330)
Sep 3 15:06:39 i5 kernel: [ 1696.025689] ata1.01: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Sep 3 15:06:39 i5 kernel: [ 1696.028114] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN0.DRV1._GTF.DSSP], AE_NOT_FOUND (20210730/psargs-330)
Sep 3 15:06:39 i5 kernel: [ 1696.028123]
Sep 3 15:06:39 i5 kernel: [ 1696.028125] No Local Variables are initialized for Method [_GTF]
Sep 3 15:06:39 i5 kernel: [ 1696.028126] No Arguments are initialized for method [_GTF]
Sep 3 15:06:39 i5 kernel: [ 1696.028127]
Sep 3 15:06:39 i5 kernel: [ 1696.028128] ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN0.DRV1._GTF due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Sep 3 15:06:39 i5 kernel: [ 1696.229223] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.CHN0.DRV0._GTF.DSSP], AE_NOT_FOUND (20210730/psargs-330)
Sep 3 15:06:39 i5 kernel: [ 1696.229232]
Sep 3 15:06:39 i5 kernel: [ 1696.229233] No Local Variables are initialized for Method [_GTF]
Sep 3 15:06:39 i5 kernel: [ 1696.229234] No Arguments are initialized for method [_GTF]
Sep 3 15:06:39 i5 kernel: [ 1696.229235]
Sep 3 15:06:39 i5 kernel: [ 1696.229236] ACPI Error: Aborting method \_SB.PCI0.SAT0.CHN0.DRV0._GTF due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Sep 3 15:06:39 i5 kernel: [ 1696.231720] ata1.00: configured for UDMA/133
Sep 3 15:06:39 i5 kernel: [ 1696.237144] ata1.01: configured for UDMA/133
Sep 3 15:06:39 i5 systemd-sleep[9301]: /dev/sdb:
Sep 3 15:06:39 i5 systemd-sleep[9301]: setting Advanced Power Management level to 0xfe (254)
Sep 3 15:06:39 i5 systemd-sleep[9301]: APM_level#011= 254
Sep 3 15:06:39 i5 systemd-sleep[9401]: /dev/sdc:
Sep 3 15:06:39 i5 systemd-sleep[9401]: setting Advanced Power Management level to 0xfe (254)
Sep 3 15:06:39 i5 systemd-sleep[9401]: APM_level#011= 254
Sep 3 15:06:40 i5 kernel: [ 1697.505749] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 330)
Sep 3 15:06:40 i5 kernel: [ 1697.508105] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT1.CHN0.DRV0._GTF.DSSP], AE_NOT_FOUND (20210730/psargs-330)
Sep 3 15:06:40 i5 kernel: [ 1697.508115]
Sep 3 15:06:40 i5 kernel: [ 1697.508116] No Local Variables are initialized for Method [_GTF]
Sep 3 15:06:40 i5 kernel: [ 1697.508117]
Sep 3 15:06:40 i5 kernel: [ 1697.508118] No Arguments are initialized for method [_GTF]
Sep 3 15:06:40 i5 kernel: [ 1697.508120] ACPI Error: Aborting method \_SB.PCI0.SAT1.CHN0.DRV0._GTF due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Sep 3 15:06:40 i5 kernel: [ 1697.513016] ata3.00: configured for UDMA/133
Sep 3 15:06:40 i5 systemd-sleep[9443]: /dev/sdd:
Sep 3 15:06:40 i5 systemd-sleep[9443]: setting Advanced Power Management level to 0xfe (254)
Sep 3 15:06:40 i5 systemd-sleep[9443]: APM_level#011= 254
Sep 3 15:06:41 i5 systemd[1]: systemd-suspend.service: Deactivated successfully.
Sep 3 15:06:41 i5 systemd[1]: Finished System Suspend.
Sep 3 15:06:41 i5 systemd[1]: Stopped target Sleep.
Sep 3 15:06:41 i5 systemd[1]: Reached target Suspend.
Sep 3 15:06:41 i5 systemd[1]: Stopped target Suspend.
Sep 3 15:06:41 i5 NetworkManager[1566]: <info> [1693764401.0498] manager: sleep: wake requested (sleeping: yes enabled: yes)
Sep 3 15:06:41 i5 ModemManager[1729]: <info> [sleep-monitor-systemd] system is resuming
Sep 3 15:06:41 i5 NetworkManager[1566]: <info> [1693764401.0498] device (eno1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Sep 3 15:06:41 i5 rtkit-daemon[2035]: Supervising 7 threads of 2 processes of 2 users.
Sep 3 15:06:41 i5 rtkit-daemon[2035]: Successfully made thread 9572 of process 2159 owned by '115' RT at priority 5.
Sep 3 15:06:41 i5 rtkit-daemon[2035]: Supervising 8 threads of 2 processes of 2 users.
Sep 3 15:06:41 i5 NetworkManager[1566]: <info> [1693764401.2682] manager: NetworkManager state is now CONNECTED_LOCAL
Sep 3 15:06:43 i5 ModemManager[1729]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:19.0': not supported by any plugin
Sep 3 15:06:44 i5 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Sep 3 15:06:44 i5 NetworkManager[1566]: <info> [1693764404.7337] device (eno1): carrier: link connected
Sep 3 15:06:44 i5 NetworkManager[1566]: <info> [1693764404.7340] device (eno1): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Sep 3 15:06:44 i5 NetworkManager[1566]: <info> [1693764404.7348] policy: auto-activating connection 'Wired connection 1' (32edaee2-eb43-3a83-8219-c47ac2e3933a)
Sep 3 15:06:44 i5 kernel: [ 1701.279834] e1000e 0000:00:19.0 eno1: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
Sep 3 15:06:44 i5 kernel: [ 1701.279879] IPv6: ADDRCONF(NETDEV_CHANGE): eno1: link becomes ready
Sep 3 15:06:44 i5 NetworkManager[1566]: <info> [1693764404.7353] device (eno1): Activation: starting connection 'Wired connection 1' (32edaee2-eb43-3a83-8219-c47ac2e3933a)
Sep 3 15:06:44 i5 NetworkManager[1566]: <info> [1693764404.7354] device (eno1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Sep 3 15:06:44 i5 NetworkManager[1566]: <info> [1693764404.7357] manager: NetworkManager state is now CONNECTING
Sep 3 15:06:44 i5 NetworkManager[1566]: <info> [1693764404.7359] device (eno1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Sep 3 15:06:44 i5 NetworkManager[1566]: <info> [1693764404.7363] device (eno1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Sep 3 15:06:44 i5 NetworkManager[1566]: <info> [1693764404.7372] dhcp4 (eno1): activation: beginning transaction (timeout in 45 seconds)
Sep 3 15:06:44 i5 avahi-daemon[1562]: Joining mDNS multicast group on interface eno1.IPv6 with address fe80::a338:da0a:7c02:12c8.
Sep 3 15:06:44 i5 avahi-daemon[1562]: New relevant interface eno1.IPv6 for mDNS.
Sep 3 15:06:44 i5 avahi-daemon[1562]: Registering new address record for fe80::a338:da0a:7c02:12c8 on eno1.*.
Sep 3 15:06:47 i5 python3[2912]: Received a timestamp of 0; window activation may not function properly.
Sep 3 15:06:47 i5 org.mate.panel.applet.DockAppletFactory[3787]: [3788:3807:0903/150647.364959:ERROR:get_updates_processor.cc(261)] PostClientToServerMessage() failed during GetUpdates with error 2
Sep 3 15:06:47 i5 org.mate.panel.applet.DockAppletFactory[3787]: [3788:3808:0903/150647.819857:ERROR:get_updates_processor.cc(261)] PostClientToServerMessage() failed during GetUpdates with error 2
Sep 3 15:06:50 i5 NetworkManager[1566]: <info> [1693764410.4712] dhcp6 (eno1): activation: beginning transaction (timeout in 45 seconds)
Sep 3 15:06:50 i5 avahi-daemon[1562]: Leaving mDNS multicast group on interface eno1.IPv6 with address fe80::a338:da0a:7c02:12c8.
Sep 3 15:06:50 i5 avahi-daemon[1562]: Joining mDNS multicast group on interface eno1.IPv6 with address 2804:14c:b6:9601:10cf:5875:abfe:2ef7.
Sep 3 15:06:50 i5 avahi-daemon[1562]: Registering new address record for 2804:14c:b6:9601:10cf:5875:abfe:2ef7 on eno1.*.
Sep 3 15:06:50 i5 avahi-daemon[1562]: Withdrawing address record for fe80::a338:da0a:7c02:12c8 on eno1.
Sep 3 15:06:50 i5 NetworkManager[1566]: <info> [1693764410.6443] dhcp4 (eno1): state changed new lease, address=192.168.0.48
Sep 3 15:06:50 i5 avahi-daemon[1562]: Joining mDNS multicast group on interface eno1.IPv4 with address 192.168.0.48.
Sep 3 15:06:50 i5 avahi-daemon[1562]: New relevant interface eno1.IPv4 for mDNS.
Sep 3 15:06:50 i5 avahi-daemon[1562]: Registering new address record for 192.168.0.48 on eno1.IPv4.
Sep 3 15:06:50 i5 dbus-daemon[1565]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.10' (uid=0 pid=1566 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined")
Sep 3 15:06:50 i5 NetworkManager[1566]: <info> [1693764410.6467] device (eno1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Sep 3 15:06:50 i5 systemd[1]: Starting Network Manager Script Dispatcher Service...
Sep 3 15:06:50 i5 dbus-daemon[1565]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Sep 3 15:06:50 i5 systemd[1]: Started Network Manager Script Dispatcher Service.
Sep 3 15:06:50 i5 NetworkManager[1566]: <info> [1693764410.6586] device (eno1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Sep 3 15:06:50 i5 NetworkManager[1566]: <info> [1693764410.6587] device (eno1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Sep 3 15:06:50 i5 NetworkManager[1566]: <info> [1693764410.6591] manager: NetworkManager state is now CONNECTED_LOCAL
Sep 3 15:06:50 i5 NetworkManager[1566]: <info> [1693764410.6595] manager: NetworkManager state is now CONNECTED_SITE
Sep 3 15:06:50 i5 NetworkManager[1566]: <info> [1693764410.6596] policy: set 'Wired connection 1' (eno1) as default for IPv4 routing and DNS
Sep 3 15:06:50 i5 NetworkManager[1566]: <info> [1693764410.6598] policy: set 'Wired connection 1' (eno1) as default for IPv6 routing and DNS
Sep 3 15:06:50 i5 NetworkManager[1566]: <info> [1693764410.6604] device (eno1): Activation: successful, device activated.
Sep 3 15:06:50 i5 NetworkManager[1566]: <info> [1693764410.6608] manager: NetworkManager state is now CONNECTED_GLOBAL
Sep 3 15:06:50 i5 dbus-daemon[2052]: [session uid=1000 pid=2052] Activating service name='org.freedesktop.Notifications' requested by ':1.46' (uid=1000 pid=2977 comm="nm-applet --indicator " label="unconfined")
Sep 3 15:06:50 i5 kernel: [ 1707.214361] audit: type=1107 audit(1693764410.663:117): pid=1565 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_signal" bus="system" path="/org/freedesktop/GeoClue2/Manager" interface="org.freedesktop.DBus.Properties" member="PropertiesChanged" name=":1.121" mask="receive" pid=3216 label="/usr/bin/redshift" peer_pid=3227 peer_label="unconfined"
Sep 3 15:06:50 i5 kernel: [ 1707.214361] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Sep 3 15:06:50 i5 systemd-resolved[1451]: eno1: Bus client set search domain list to: home
Sep 3 15:06:50 i5 dnsmasq[1998]: reading /etc/resolv.conf
Sep 3 15:06:50 i5 dnsmasq[1998]: using nameserver 127.0.0.53#53
Sep 3 15:06:50 i5 systemd-resolved[1451]: eno1: Bus client set default route setting: yes
Sep 3 15:06:50 i5 systemd-resolved[1451]: eno1: Bus client set DNS server list to: 181.213.132.2, 181.213.132.3, 2804:14d:1:0:181:213:132:2, 2804:14d:1:0:181:213:132:3
Sep 3 15:06:50 i5 mate-notificati[9632]: Failed to load module "xapp-gtk3-module"
Sep 3 15:06:50 i5 nm-dispatcher[9658]: /etc/network/if-up.d/resolved: 12: mystatedir: not found
Sep 3 15:06:50 i5 geoclue[3227]: Failed to query location: Error resolving “location.services.mozilla.com”: Name or service not known
Sep 3 15:06:50 i5 nm-dispatcher[9691]: /etc/network/if-up.d/resolved: 12: mystatedir: not found
Sep 3 15:06:50 i5 dbus-daemon[2052]: [session uid=1000 pid=2052] Successfully activated service 'org.freedesktop.Notifications'
Sep 3 15:06:51 i5 NetworkManager[1566]: <info> [1693764411.5702] dhcp6 (eno1): state changed new lease, address=2804:14c:b6:9601::1f3a
Sep 3 15:06:51 i5 avahi-daemon[1562]: Registering new address record for 2804:14c:b6:9601::1f3a on eno1.*.
Sep 3 15:06:51 i5 avahi-daemon[1562]: Registering new address record for 2804:14c:b6:9601:a2f0:94ff:9282:a87f on eno1.*.
Sep 3 15:07:01 i5 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Sep 3 15:07:06 i5 ModemManager[1729]: <info> [device /sys/devices/pci0000:00/0000:00:16.3] creating modem with plugin 'generic' and '1' ports
Sep 3 15:07:06 i5 ModemManager[1729]: <warn> [plugin/generic] could not grab port ttyS4: Cannot add port 'tty/ttyS4', unhandled port type
Sep 3 15:07:06 i5 ModemManager[1729]: <warn> [base-manager] couldn't create modem for device '/sys/devices/pci0000:00/0000:00:16.3': Failed to find primary AT port
Sep 3 15:07:53 i5 python3[2912]: Received a timestamp of 0; window activation may not function properly.
Sep 3 15:13:41 i5 python3[2912]: Received a timestamp of 0; window activation may not function properly.
Sep 3 15:14:16 i5 code[10750]: Failed to load module "xapp-gtk3-module"
Sep 3 15:14:16 i5 dbus-daemon[1565]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.167' (uid=1000 pid=10750 comm="/usr/share/code/code --unity-launch /mnt/F/dev/lin" label="unconfined")
Sep 3 15:14:16 i5 systemd[1]: Condition check resulted in Bluetooth service being skipped.
Sep 3 15:14:20 i5 python3[2912]: Received a timestamp of 0; window activation may not function properly.
Sep 3 15:15:01 i5 CRON[10910]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Sep 3 15:15:10 i5 systemd-resolved[1451]: Clock change detected. Flushing caches.
Sep 3 15:15:10 i5 systemd-timesyncd[1452]: Initial synchronization to time server [2620:2d:4000:1::40]:123 (ntp.ubuntu.com).
Sep 3 15:16:40 i5 python3[2912]: Received a timestamp of 0; window activation may not function properly.
Sep 3 15:16:48 i5 python3[2912]: Received a timestamp of 0; window activation may not function properly.
Sep 3 15:17:01 i5 CRON[11235]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Sep 3 15:20:16 i5 python3[2912]: Received a timestamp of 0; window activation may not function properly.
Sep 3 15:22:41 i5 dbus-daemon[2215]: [session uid=115 pid=2211] Activating service name='org.freedesktop.Notifications' requested by ':1.6' (uid=115 pid=2365 comm="/usr/lib/unity-settings-daemon/unity-settings-daem" label="unconfined")
Sep 3 15:22:41 i5 dbus-daemon[2215]: [session uid=115 pid=2211] Successfully activated service 'org.freedesktop.Notifications'
Sep 3 15:23:40 i5 NetworkManager[1566]: <info> [1693765420.3494] manager: sleep: sleep requested (sleeping: no enabled: yes)
Sep 3 15:23:40 i5 NetworkManager[1566]: <info> [1693765420.3495] manager: NetworkManager state is now ASLEEP
Sep 3 15:23:40 i5 ModemManager[1729]: <info> [sleep-monitor-systemd] system is about to suspend
Sep 3 15:23:40 i5 NetworkManager[1566]: <info> [1693765420.3499] device (eno1): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Sep 3 15:23:40 i5 dbus-daemon[1565]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.10' (uid=0 pid=1566 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined")
Sep 3 15:23:40 i5 kernel: [ 2716.385135] audit: type=1107 audit(1693765420.353:118): pid=1565 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="ALLOWED" operation="dbus_signal" bus="system" path="/org/freedesktop/GeoClue2/Manager" interface="org.freedesktop.DBus.Properties" member="PropertiesChanged" name=":1.121" mask="receive" pid=3216 label="/usr/bin/redshift" peer_pid=3227 peer_label="unconfined"
Sep 3 15:23:40 i5 kernel: [ 2716.385135] exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
Sep 3 15:23:40 i5 systemd[1]: Starting Network Manager Script Dispatcher Service...
Sep 3 15:23:40 i5 dbus-daemon[1565]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Sep 3 15:23:40 i5 systemd[1]: Started Network Manager Script Dispatcher Service.
Sep 3 15:23:40 i5 NetworkManager[1566]: <info> [1693765420.3695] device (eno1): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Sep 3 15:23:40 i5 avahi-daemon[1562]: Withdrawing address record for
