System Update Issues
I was getting errors when downloading updates and advised to check Internet connections. The process seemed to be hanging on webupd8 TOR-Browser. I did try various servers and got the same results. So I removed Tor and tried again, then the hang appeared with webupd8 Java. So I then did the following commands
sudo rm -rvf /var/lib/apt/lists/*
rebooted
sudo apt-get update
Then I get a timeout at
0% [Connecting to archive.getdeb.net (144.76.200.19)]
I then went to Software Boutique and Upgraded Installed packages, nothing to upgrade.
Then Resolve Broken Packages, Says all broken packages fixed.
But I still get errors trying to update.
Are there currently issues in the community updating or do I need to fix my update configuration?
Hello
Please post the exact error messages you get when you use the following commands in the terminal:
sudo apt update
sudo apt full-upgrade
Then please post the output of:
inxi -r
sudo apt update
Err:25 Ubuntu - GetDeb xenial-getdeb InRelease
Could not connect to archive.getdeb.net:80 (144.76.200.19), connection timed out
Fetched 2,456 kB in 2min 0s (20.4 kB/s)
Reading package lists... Done
Building dependency tree
1 package can be upgraded. Run 'apt list --upgradable' to see it.
W: Failed to fetch http://archive.getdeb.net/ubuntu/dists/xenial-getdeb/InRelease Could not connect to archive.getdeb.net:80 (144.76.200.19), connection timed out
W: Some index files failed to download. They have been ignored, or old ones used instead.
Err:1 http://download.opensuse.org/repositories/home:/stevenpusser/xUbuntu_16.04 palemoon 27.4.0~repack-1
404 Not Found [IP: 195.135.221.134 80]
E: Failed to fetch http://download.opensuse.org/repositories/home:/stevenpusser/xUbuntu_16.04/./amd64/palemoon_27.4.0~repack-1_amd64.deb 404 Not Found [IP: 195.135.221.134 80]
E: Unable to fetch some archives, maybe run apt-get update or try with –fix-missing?
sudo apt update –fix-missing
Get:17 http://download.opensuse.org/repositories/home:/stevenpusser/xUbuntu_16.04 Packages [2,483 B]
Err:18 Ubuntu - GetDeb xenial-getdeb InRelease
Fetched 310 kB in 2min 0s (2,583 B/s)
All packages are up to date.
sudo apt full-upgrade –fix-missing
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
inxi -r
Repos: Active apt sources in file: /etc/apt/sources.list
deb Index of /ubuntu xenial main restricted
deb Index of /ubuntu xenial-updates main restricted
deb Index of /ubuntu xenial universe
deb Index of /ubuntu xenial-updates universe
deb Index of /ubuntu xenial multiverse
deb Index of /ubuntu xenial-updates multiverse
deb Index of /ubuntu xenial-backports main restricted universe multiverse
deb Index of /ubuntu xenial partner
deb-src Index of /ubuntu xenial partner
deb Index of /ubuntu xenial-security main restricted
deb Index of /ubuntu xenial-security universe
deb Index of /ubuntu xenial-security multiverse
Active apt sources in file: /etc/apt/sources.list.d/getdeb.list
deb Ubuntu - GetDeb xenial-getdeb apps
Active apt sources in file: /etc/apt/sources.list.d/google-chrome.list
deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
Active apt sources in file: /etc/apt/sources.list.d/jre-phoenix-ubuntu-ppa-xenial.list
deb Index of /jre-phoenix/ppa/ubuntu xenial main
Active apt sources in file: /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-xenial.list
deb Index of /libreoffice/ppa/ubuntu xenial main
deb-src Index of /libreoffice/ppa/ubuntu xenial main
Active apt sources in file: /etc/apt/sources.list.d/palemoon.list
deb http://download.opensuse.org/repositories/home:/stevenpusser/xUbuntu_16.04/ /
Active apt sources in file: /etc/apt/sources.list.d/ubuntu-mate-dev-ubuntu-welcome-xenial.list
deb Index of /ubuntu-mate-dev/welcome/ubuntu xenial main
deb-src Index of /ubuntu-mate-dev/welcome/ubuntu xenial main
Active apt sources in file: /etc/apt/sources.list.d/virtualbox.list
deb Index of http://download.virtualbox.org/virtualbox/debian xenial contrib
Active apt sources in file: /etc/apt/sources.list.d/webupd8team-ubuntu-java-xenial.list
deb Index of /webupd8team/java/ubuntu xenial main
Just an update since PaleMoon was updated during one of my checks today.
sudo apt update
same results as above
Hallo jaybo
Something similar happened to me recently. I’d forgotten that I’d had the same problem around two years ago, but a wise owl suggested the problem might be caused by ppa packages.
I deactivated the update for all the ppa packages on my system. Then I reactivated the ppa packages one by one, running the software updater again after each package was reactivated. By this process of elimination I was able to identify two ppa packages that caused the update process to fail.
Perhaps this might solve your problem too. :slight_smile:
Yeah, or just wipe the offending repo. Hint: it’s this one:
deb http://archive.getdeb.net/ubuntu xenial-getdeb apps
After entering the commands for the requested output I see “http://archive.getdeb.net” is the bad site. You can’t even go there by browser. Thank you for that drill as I did learn from it.
Yes I can remove the getdeb.net link to eliminate the error. However, those associated apps will no longer be updated. So that brings another question in play which I can’t find an answer for through my searches. How do I see what apps are associated with getdeb?
I assumed getdeb was a reputable Ubuntu software source. Is getdeb.net gone for good or are they simply having server challenges?
Although I did not find what apps are associated with getdeb, I did find a list of getdeb mirrors on WEBUPD8. So I went to Admin/Software & Updates, clicked on Other Software, and added a mirror site “deb http://mirrors.dotsrc.org/getdeb/ubuntu xenial-getdeb apps”, then unchecked “http://archive.getdeb.net/ubuntu”. All is working good again.
