hello -
i’m on MATE 15.04 on laptop
i have little problem at start-up : systemd-modules-load.service - Load Kernel Modules failed
fred@fred-GX720:~$ sudo systemctl status systemd-modules-load
[sudo] password for fred:
● systemd-modules-load.service - Load Kernel Modules
Loaded: loaded (/lib/systemd/system/systemd-modules-load.service; static; vendor preset: enabled)
Active: failed (Result: exit-code) since lun. 2015-06-15 04:46:48 CEST; 7min ago
Docs: man:systemd-modules-load.service(8)
man:modules-load.d(5)
Process: 229 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
Main PID: 229 (code=exited, status=1/FAILURE)
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
fred@fred-GX720:~$
what’s the problem? if someone can help me…thx
