I’m running Telegram 1.0.27 but there is no icon anymore?
Can anyone confirm or has a workaround? Thx
I’ll fix the PPA. Next update should resolve the issue.
Thx, I just tried the ppa version and can confirm it does not work.
But I’m sure I tried the telegram binary before and it worked without the need for the ppa one?
@Wimpy are these issues related?
Since I'm not a native english speaker I kinda have the impression we are talking about different things.
What I am relating to is the notification area, where you can also see the network icon
or where you can see the steam icon etc.
Some programms won't show the tray icon, even though you can see a small change in that area.
It may just not be visible and also not clickable
