Hi, I have a Raspberry Pi2 running Ubuntu Mate 16.04. I'm not sure what happened but the mate-terminal will no longer open.
I've tried ctrl+alt+t
as well as 'right click + open in terminal' and from the applications menu. From the applications menu, at the bottom I get the tab "starting terminal" but then it just disappears.
How can I fix this ? Thanks.
