I've just updated from 21.10 to 22.04 where I had a completely normal working mouse to now its really laggy and slow. I've tried adjusting the usbhid.mousepoll settings in cmdline.txt and its made it slightly better but nowhere near what it was like.
Whats changed between releases to make this happen?
Was this a clean install of the OS? I ask because the last time I played with the R-Pi was when the 22.04 image was released and I had no problems as you describe. In fact I was really impressed with how smooth the experience was.
If you did an in place upgrade rather than a fresh install, that may account for the difference. If you did a fresh install then either there's been a regression or it's a hardware problem. One thing I would do is replace the battery in the mouse if you're using a wireless mouse.
As expected, the in place upgrade looks to have broken something.
I installed Mate 22.04 to a spare micro sd card and booted up, I had to add usbhid.mousepoll=0 to the cmdline.txt file, however after doing that it was fine.
Solved... I deactivate the option ... so no more 3D acceleration ... now mouse behave normally.
The KMS does not work on 22.04 Pi3 armhf, just Legacy and FKMS... prefer legacy because of mouse issues.
