Pointrelease is released, yay !!
So I decided today to upgrade my mediacenter from 22.04 to 24.04:
Machine:
Type: Desktop Mobo: ASRock model: J4205-ITX serial: <superuser required>
UEFI: American Megatrends v: P1.80 date: 05/21/2018
CPU:
quad core Intel Pentium J4205 (-MCP-) speed/min/max: 1035/800/2600 MHz
TDP: < 10 Watt / Fanless
Kernel:
6.8.0-41-generic x86_64 Up: 5m Mem: 868.8 MiB/7.17 GiB (11.8%)
Graphics:
Device-1: Intel Apollo Lake [HD Graphics 505] driver: i915 v: kernel
Display: server: X.org v: 1.21.1.11 driver: X: loaded: modesetting unloaded: fbdev,vesa
dri: iris gpu: i915 tty: 104x55 resolution: 1: 1920x1200 2: 1280x1024
API: EGL v: 1.5 drivers: iris,swrast platforms: surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 24.0.9-0ubuntu0.1 note: console (EGL sourced)
renderer: Mesa Intel HD Graphics 505 (APL 3), llvmpipe (LLVM 17.0.6 128 bits)
I had my fingers crossed as usual because I use VAAPI hardware acceleration for videoplayback and that means manual intervention after every release upgrade because sometimes libva / libmesa related stuff is missing/not-installed/version mismatch and sometimes mpv changes implementation of options which forces me to modify my mpv.config c.q. config-generator.
The Upgrade
screenlocking
Before the upgrade process really started, the system complained that it couldn't deactivate screenlocking without so much as a hint how that should be done.
I still haven't the slightest idea what the installer wanted me to do, but since I do not use a screensaver or a display time-out on this home brew appliance I deemed it OK to continue the upgrade.
cryptsetup ?!?
During the upgrade, the installer complained about not being able to install cryptsetup ( which I don't use and don't care about anyway ) but it finished beautifully nevertheless.
The first update afterwards, the update-manager complained about cryptsetup again and wanted a partial upgrade.
Big Fun
, because as usual, the update-manager starts happily doing that and is completely oblivious that it is always failing to succeed in the end
I ended up doing it from the commandline which worked flawlessly.
settings were preserved
All my settings were preserved i.e. it was exactly the same as before ( except for some minor panel-app related options ).
( @mickee , you are good to go
core task: mediacenter
VAAPI (hardware assisted video decoding on intel)
Did not work immediately because allegedly some codecs moved from the intel-media-va-driver to the intel-media-va-driver-non-free which took me some time to discover.
After installing the intel-media-va-driver-non-free everything video worked as expected.
audio
I was prepared to face some pipewire troubles but all audio worked out of the box, including S/PDIF and multichannel DTS and AC3 over optical fiber (toslink/lightpipe).
conclusion
This was seriously quite a painless upgrade.
