The Advanced MATE Menu has turned invisible
I have tried several different variations of removing and adding it, restarting etc. I can tell it is activating because my active window becomes unfocused when pressing the Super key. I would use Brisk as an alternative but no keybinding is useless and the default menu is awful.
Does anyone have any ideas?
Hi @Ross_McLean, try this…
Right-click -> Preferences
On the Plugins tab raise Opacity: (is it zero?)
HTH
I solved it on IRC. We thought it was related to the Arc theme doing something odd, and so changing theme seemed to fix it, but I have got a feeling you are spot on. Thanks.
For reference, here's the log:
https://irclogs.ubuntu.com/2017/06/23/%23ubuntu-mate.html#t23:03
