Hi ihave a old Lenovo 91z all in one pc i am trying to revive all is well so far but i need wireless drivers? Could anyone help?
Have you already installed Ubuntu MATE? If so, which version?
If UM is installed and running (albeit perhaps without a wireless connection), then you can open the "Software and Updates" app from the Administration tab of the panel menu. In the dialog, select the "Additional Drivers" tab, and let it search for drivers. Whether it does/doesn't find any, please let us know, and we'll try to help further.
Hi I am using 24.04.3 LTS
I have tried that, no luck i have also done apt update/upgrade. Sadly nothing still.
As the first step I'd suggest to find out if your system lists wireless adapter in question. E.g.
$sudo lshw -short | grep -i wireless
/0/100/1c.3/0 wlp3s0 network QCA9565 / AR9565 Wireless Network Adapter
Or
$sudo lshw -C network
*-network
description: Wireless interface
product: QCA9565 / AR9565 Wireless Network Adapter
vendor: Qualcomm Atheros
configuration: broadcast=yes driver=ath9k driverversion=6.8.0-85-generic
Or
$inxi -N
Network:
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
driver: ath9k
Pretty sure you have a broadcom wireless device; if so, the guide here may help: https://askubuntu.com/questions/55868/installing-broadcom-wireless-drivers
If you share the output of that command with the Community, someone may spot something specific which they can address to assist you.
Hi
$sudo lshw -short | grep -i wireless produces no output, i can see the wired LAN but nothing is mentioned about the wi-fi adaptor.
The command inxi -N shows only my ethernet adaptor no mention of wireless.
Network:
Device-1: Intel 82579LM Gigabit Network driver: e1000e
Can’t seem to see the wireless device at all. There is a option for it in the BIOS and it is turned on. I don’t see any hardware switches for the wireless. Very odd ![]()
Let's backtrack to verify assumptions:
- Did you open up the computer to confirm that the wireless interface circuitry is in fact present? or has it been removed?
Assuming the wireless interface IS there, if you boot from Live ISO, do you see the interface?
The command that will tell you if there are network devices is the following:
dmidecode -t 8 >dmidecode_inventory.txt
and that search in that report for entries that include "Network", as shown here:
Handle 0x000E, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: LAN1
Internal Connector Type: None
External Reference Designator: LAN1
External Connector Type: RJ-45
Port Type: Network Port
You will have to look for any string that suggests wireless.
ip link show
You could also try the following (with, or without, the --short option):
hwinfo --wlan --netcard --network
Also, depending on how information was "logged", do you get anything using the command
Also, to see what you come up with, maybe poke differently with
lspci -vv -nn | grep -i net
When configured, the system should report related information using
iwconfig
Lastly, if you install hardinfo2, and look under
- PCI Devices, or
- Kernel Modules
is a Wireless interface reported?
your wifi adapter can be
Hopefully, that's may be enough to begin search for proper Linux drivers.
I opened it up, there is a Intel Centrino N 1000 card in it, i believe it’s faulty as windows 10 didn’t see it either so i have ordered the same type but wireless AC so should work fine hopefully ![]()
