I was referencing a similar guide https://download.lenovo.com/pccbbs/mobiles_pdf/e14_gen2_e15_gen2_ug_en.pdf p.21 according to the serial number : 'Note: To maximize the life of the battery, once the battery is fully charged it must discharge to below 95% before it will be allowed to recharge again'.
During the first weeks of usage it was 100% on AC plugged in. I tried to check the battery and discharge it to ~97-98% several times (upon disconnecting from AC), and every time afterwards
upon plugging into the AC mains the icon showed "Charging" and charged to 100%. The upower -i /org/freedesktop/UPower/devices/battery_BAT0 shows 3 charging cycles. So probably the last time
I discharged it to 95%, hoping that it would charge to 100% again. But it was 95% for ~2 weeks while plugged into the AC.
In Windows, which I don't use currently, the battery icon showed 96%, when on Ubuntu it was 95%. Right around the time I was thinking to write a post about it, on Ubuntu it dropped to 94% (so actually it may be ~94-95%) while plugged in.
I am a bit afraid to discharge it more than 94%. If, per User Guide, the battery doesn't recharge unless the charge drops less than 95%, than how had it recharged to 100% upon initial usage when I discharged it slightly to check charging.
The laptop was always on AC, except for several times when I discharged it for ~10 minutes for testing.
Sorry for bothering, it may be a Lenovo specific issue, but I wouldn't like to leave the laptop for their service, as I need it every day.
I was thinking that if I install auto-cpufreq in balanced mode (which adapts CPU frequency to actual usage), it would override the current battery management daemon and then would it be safe?
