Good evening
I started using Ubuntu-Mate today. I really liked the top panel used. I added some folders that I use frequently.
When I open the folders using the top panel, the window opens on the main monitor and I can't move them. I can't drag them. It does not appear nor the resize keys either.
To use folders on a secondary monitor, I must open the file manager by another method (desktop, menu), not through the top panel shortcut.
Can anyone tell why this?
Note: only happens with folder windows.
Thank you very much in advance.
