Please, why is not possible to have Tor in Raspberry Pi? i suggest as future version, it would be very usefull.
asis
thanks very much, i’m afraid not. I am a dummy that use Tor in Windows and try to repeat in Ubuntu… but… too much dificult for my knowledges
thanks so much
Asis
Hi Asis,
what about this then?:
http://makezine.com/projects/browse-anonymously-with-a-diy-raspberry-pi-vpntor-router/
From the looks of things, The Tor Browser doesn’t have any packages available for it, which means it cannot be easily installed with a few clicks.
Software is compiled to run on a specific type of hardware – the most common being PCs: i386 and amd64 (sometimes called x86 and x86_64 or x64 in Windows). The Raspberry Pi’s is armhf.
You can get it to run, which is to build it for armhf and then install/run it. I came across this which suggests installing tor to use the Tor network (depends if tor is packaged for armhf), but this doesn’t include the Tor Browser.
thanks Wolfman, i’m trying just to navigate anonymous, as I can do it in windows with Tor. This is not what i’m looking for. just a simple “install Tor and run” or almost…
asi s
thanks lah7, I installed Tor and use the socks:9050… as you show me, better than before, not?
how can i know if i am navigatin anonymous?.
It’s a pitty not be possible run a “standar” instalation of wonderfull Tor in Raspberry Pi.
asis
I’m no Tor user, but I believe your IP is anonymized when using the Tor network. Try visiting http://whatismyip.com and see if it’s different each time you refresh.
not… but thanks Lah7
asis
Get it
in terminal:
sudo -i (to be superuser)
apt-get install tor (install Tor)
sudo apt-get install tor (run Tor service)
in firefox > preferences > advanced > net > conexion > settings
manual proxy cnfiguration
servidor socks: 127.0.0.1 port 9050
socks5 y dns remote activated
close firefox
reset Pi
and… done¡¡¡
go to https://check.torproject.org/ and
thanks to all the people who give me links and ideas to get it.
Asis
Hello, it didnt work on my raspberry pi 3 model b with kali linux, i need some help, I TRIED EVERYTHING
What kind of kali distro are you using? Did you check the signature sha256sum *.iso
