To enable touch input the same way with two different inputs (and input libs) on modern laptops and netbooks, in UM17.04.
Touchpad gestures (libinput)
[edit] Works well but there is a compiz problem which is annoying. It prevent multiple xdotool calls until a real keyboard input is made. I work on a solution, or a workaround like a d-bus call for compiz
Works well with libinput-gestures
sudo gpasswd -a $USER input
sudo apt-get install xdotool wmctrl libinput-tools
git clone http://github.com/bulletmark/libinput-gestures
cd libinput-gestures
sudo ./libinput-gestures-setup install
libinput-gestures-setup start
Then for example create the following .config/libinput-gestures.conf :
gesture swipe up 3 xdotool key super+w
gesture swipe up 4 xdotool key super+a
gesture swipe down xdotool key ctrl+alt+d
gesture swipe left xdotool key alt+Right
gesture swipe right xdotool key alt+Left
If it runs well, you can add the service in startup item
libinput-gestures-setup autostart
then trash the installation directory
Touchscreen gestures (synaptics)
Add the touchegg service
sudo apt install touchegg
mkdir $HOME/touchegg
touch $HOME/touchegg/touchegg.conf
pluma $HOME/touchegg/touchegg.conf
Configuration example with same input gestures than with touchpad:
<touchégg>
<settings>
<property name="composed_gestures_time">111</property>
</settings>
<application name="All">
<gesture type="DRAG" fingers="3" direction="UP">
<action type="SEND_KEYS">Super+w</action>
</gesture>
<gesture type="DRAG" fingers="4" direction="UP">
<action type="SEND_KEYS">Super+a</action>
</gesture>
<gesture type="DRAG" fingers="3" direction="DOWN">
<action type="SEND_KEYS">ctrl+alt+d</action>
</gesture>
<gesture type="DRAG" fingers="4" direction="DOWN">
</gesture>
<gesture type="DRAG" fingers="3" direction="LEFT">
<action type="SEND_KEYS">alt+Right</action>
</gesture>
<gesture type="DRAG" fingers="3" direction="RIGHT">
<action type="SEND_KEYS">alt+Left</action>
</gesture>
<gesture type="TAP" fingers="2" direction="">
<action type="MOUSE_CLICK">BUTTON=3</action>
</gesture>
</application>
</touchégg>
Then add the touchegg command in the Startup Applications
