Touch screen not change when display rotated
In brief, I use pi3 with touch screen. due to my pi’case I must rotate the screen 180 degree (the power line phone line hdmi will be up).
http://www.freebuf.com/geek/91402.html
https://item.taobao.com/item.htm?spm=a230r.1.14.35.hSrXsi&id=522216149713&ns=1&abbucket=5#detail
https://item.taobao.com/item.htm?spm=2013.1.20141001.3.8UdnHz&id=538763057812&scm=1007.10115.70237.100200300000000&pvid=7f07f666-e7ae-4b46-b0fb-b0ce5bf7e127&idnum=0
when I install ubuntu mate completely, the screen is in normal mode everything is ok, issues coming after I change config.txt in boot partition which I modify lcd_rotate=2 (rotate 180 degree).the mouse does not show in the touch point, on the country the anti corner eg I touch up-left it showed in down-right i touch down-left it shows in up-right.
obviously screen show rotate but touch screen less the corresponding handling.I love ubuntu mate so I hope to work this problem out like raspbian.Thank you.
A solution to this issue can be found in [Tutorial] - How to rotate touchscreen input after rotating display? - #2 by apandada1
