Touchpad is not working on my Asus R417N
Greetings. This is my first post.
I bought this Asus R417N, which is a really cheap computer which that comes with Windows 10 installed. However, I decided to change my operative system in this laptop because I’m kinda tired of Microsoft and also because Linux is really cool for learning some computing skills.
I downloaded the latest ISO image aviable in the website (17.10), and now that I have deleted my Windows 10 OS and also have completely replaced it with Ubuntu Mate, I find out that my touchpad is not working correctly. Every time I turn on my laptop I’m able to use my touchpad for like 10 seconds and then the arrow gets frozen and I have to connect my USB mouse in order to be able to fully use my computer.
I thank you really much for your help.
Hi @Mauricio_Bautista,
have you done all your updates?, take a look at the following guide and then get back to us if it doesn't help. :smiley:
Hi again. Thank you for your help.
I have updated everything according to what is suggested in the link you gave to me, including the drivers and have also installed all the synaptics packs.
I have been analyzing this problem and it seems like the touchpad driver gets deactivated, but the system is not realizing about that and when I open the system > preferences > hardware > mouse, touchpad appears as if it was enabled.
I’ve also tried it with the sudo nano /etc/default/grub, and changing the line with quiet splash with
GRUB_CMDLINE_LINUX_DEFAULT=“quiet splash i8042.kbdreset=1”
Have also tried this procedure with :
i8042.nomux=1
psmouse.resolution=1200
psmouse.resetafter=1
psmouse.rate=50
psmouse.smartscroll=1
mousedev.xres=1900
mousedev.yres=800
None of this commands has worked :frowning:
According to what i have found on the web, I have been able to see the name of the hardware of my laptop, which is the next one:
mauricio@mauricio-E402NA:~$ xinput list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ PixArt Microsoft USB Optical Mouse id=14 [slave pointer (2)]
⎜ ↳ ELAN1200:00 04F3:3045 Touchpad id=11 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Asus Wireless Radio Control id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ Sleep Button id=9 [slave keyboard (3)]
↳ USB2.0 VGA UVC WebCam: USB2.0 V id=10 [slave keyboard (3)]
↳ Asus WMI hotkeys id=12 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=13 [slave keyboard (3)]
¿What should I do now?
there are some suggestions here which may help you, I don’t have one myself so good luck:
https://askubuntu.com/questions/763584/elantech-touchpad-not-working-on-ubuntu-16-04-and-arch-linux :smiley:
