I have ticked “Pointer can be controlled using the keypad” under Keyboard preferences, no joy. The touch screen works and a generic wireless mouse works, but no touchpad. How do I get it working?
The laptop I’m using is a Gigabyte T1028.
try installing this package via the terminal (Ctrl + Alt + t):
gpointing-device-settings
See also:
Have you disabled the touchpad using the “FN” + combo key on your laptop?:
https://help.ubuntu.com/community/SynapticsTouchpad
https://help.ubuntu.com/community/SynapticsTouchpad/ShortcutKey
Hope it helps.
