Trouble installing BURG
Hi!!
Im trying to install Burg on my recent Ubuntu Mate and Im having troubles…
When I do…
sudo add-apt-repository ppa:n-muench/burg
sudo apt update
I have these error mesages:
E: El repositorio «http://ppa.launchpad.net/n-muench/burg/ubuntu bionic Release» no tiene un fichero de Publicación.
N: No se puede actualizar de un repositorio como este de forma segura y por tanto está deshabilitado por omisión.
N: Vea la página de manual apt-secure(8) para los detalles sobre la creación de repositorios y la configuración de usuarios.
anyone can help me?
That error means the PPA doesn’t support the version of Ubuntu you are using. This is not uncommon before a version is released. It looks like the latest they support is Xenial/16.04.
You could try installing the deb package(s) directly, but since they are made for Xenial they probably won’t work and could even damage your system. Your best bet is probably to wait and see if the PPA gets updated or find another source.
Thank you for your help.
It’s so horrible grub’s menu…!!! But I will have to wait…
I know that I’m assuming these things because this is a beta system, but I have installed it because I need a linux distribution for a JUMPER EZBOOK 3 PRO, and this is the only one it’s working on it by now, I believe.
