I have the latest Ubuntu Mate installed and have a 10.1" LCD display connected via HDMI. This display appears identical, including driver board, to the Adafruit display. The display is working., but I am trying to rotate the display 180 degrees as it is upside down in my installation. I added the following to the config,txt file:
display_rotate=2
On power up, the display is not rotated, and checking the runtime value with:
vcgencmd get_config display_rotate yields display_rotate=0
So it is not getting set for some reason. I have also tried using:
display_hdmi_rotate=2
without success.
Any help or suggestions would be appreciated.
