Hi!
I’m new to Ubuntu Mate and this community, but I must say that the OS works great, and the community seems very friendly!
Now, I’m having a bit of an issue trying to configure my OneDrive account as a folder in Caja. In Windows, I’ve used this tutorial to map it as a network drive on versions of Windows that don’t support the official OneDrive program:
I’ve successfully completed that tutorial in old versions of Windows, even as old as Win2000.
I’ve tried the following set of configs in the Connect dialog, but I always end up with the same “HTTP Error: Found” message
I’ve also tried almost all of the available connection methods, namely: FTP with login, WebDAV, Secure WebDAV and SSH without luck.
Does anyone know of a way to achieve this? Or should I download a third party app to connect to OneDrive?
Cheers, and thanks for reading!
