Trying to install gqrx radio
Does any1 know why I’m getting this error while installing gqrx-sdr? I have tried installing different packages but without success please help.
gqrx-sdr : Depends: libboost-program-options1.62.0 but it is not installable
Depends: libgnuradio-analog3.7.10 but it is not installable
Depends: libgnuradio-blocks3.7.10 but it is not installable
Depends: libgnuradio-digital3.7.10 but it is not installable
Depends: libgnuradio-fft3.7.10 but it is not installable
Depends: libgnuradio-filter3.7.10 but it is not installable
Depends: libgnuradio-osmosdr0.1.4 but it is not going to be installed
Depends: libgnuradio-pmt3.7.10 but it is not installable
Depends: libgnuradio-runtime3.7.10 but it is not installable
Apparently, I'm having problems with outdated packages when I try to update package list through welcome I get this error. Failed to download repository information.
E:The repository 'AARNet Mirror zesty Release' does not have a Release file., W:Updating from such a repository can't be done securely, and is therefore disabled by default., W:See apt-secure(8) manpage for repository creation and user configuration details., E:The repository 'AARNet Mirror zesty-updates Release' does not have a Release file., W:Updating from such a repository can't be done securely, and is therefore disabled by default., W:See apt-secure(8) manpage for repository creation and user configuration details., E:The repository 'AARNet Mirror zesty-backports Release' does not have a Release file., W:Updating from such a repository can't be done securely, and is therefore disabled by default., W:See apt-secure(8) manpage for repository creation and user configuration details., E:The repository 'Index of /ubuntu zesty-security Release' does not have a Release file., W:Updating from such a repository can't be done securely, and is therefore disabled by default., W:See apt-secure(8) manpage for repository creation and user configuration details., E:The repository 'Index of /gwibber-daily/ppa/ubuntu zesty Release' does not have a Release file., W:Updating from such a repository can't be done securely, and is therefore disabled by default., W:See apt-secure(8) manpage for repository creation and user configuration details., E:The repository 'Index of /ubuntu-mate-dev/ppa/ubuntu zesty Release' does not have a Release file., W:Updating from such a repository can't be done securely, and is therefore disabled by default., W:See apt-secure(8) manpage for repository creation and user configuration details., E:The repository 'Index of /ubuntu-mate-dev/xenial-mate/ubuntu zesty Release' does not have a Release file.
Problem with ppa packages are solved. If any1 runs into similar trouble check this link http://wimantis.ninja/fixing-ubuntu-17-04-apt-get-update-release-file-not-found/
