I installed Ubuntu for the first time in my life but I was immediately met by a challenge of not being able to connect to the internet. I have ASUS PCE-AC68 Dual-band Wireless-AC1900 Adapter. I can connect to the internet on my Windows 7 with this computer. The strange thing is I have the same Ubuntu on my laptop but it immediately recognized my wireless connection.
I typed sudo lshw on command line and got the followings:
What should I do?
Uhg, please use better formating or post the specs to pastebin, this is hard to read.
I’ve found somwhere near *-network mention of “bcma-pci-bridge” driver and “BCM4360” hardware.
Then I found:
My advice would be to try and run this command in a terminal:
sudo apt-get install bcmwl-kernel-source
Then reboot, see if that fixes things
Cheers
If it is a Broadcom unit, I also suggest using the following terminal (Ctrl + Alt + t) command and restarting:
sudo apt-get install broadcom-sta-dkms
