Hello, everyone!
I’m a long-time Linux user, ever since version 10.04. That was the distro that saved my poor laptop from Windows Vista (that is not a joke: I had to take it to repair since Vista damaged the hard drive).
When I started using Mate 24.04, I had several issues, including: OS not booting at all, much slower performance compared to 22.04, and all of my NTFS partitions were set to "read only” by default. Many software/apps run poorly, forcing me to run back to 22.04 (my current OS).
So now that we are approaching the release of 26.04, I was curious to learn about its new features. When I did some research, the first result was this video:
Now, I do not trust anything at face value. I need to have proper sources to review before having a clear picture.
These are the key points of the video:
- Relentless advertising for Ubuntu Pro (really?)
- There’s a package called “Ubuntu Advantage Tools” that cannot be removed, like it or not
- Snap packaging gets forced, even if you install the “non-snap” version of a software (Firefox is used as an example)
- You need to manually enter a command in the terminal to finish security updates (?!)
- Telemetry: collected by 4 separate tools. When you decide to opt out, it still leaks your IP address and HTTP headers, and in case of multiple users on the same machine, it still leaks data if one user decides not to opt out
Now, the video is two months old, and it could be the classic clickbait-y hollow YT video, but I’m curious to see if any of this is true. I could not find other sources to refute these arguments, that’s why I’m here! ![]()
Any insight will be appreciated! ![]()
