Hello,
I am a new user of Ubuntu MATE. I have used Ubuntu since 5.04, and now I missed the good old GUI so I decided to try out MATE
However, I cannot get the sound to work; I have a built-in soundcard and a ASUS Xonar DG PCI card, and I want to use the PCI card as default output. This works fine under Ubuntu with Unity, so I know that the card works under Linux - but no matter what I choose under MATE, the default card ends ut being the built in one.
I tried deactivating the other devices and also install PulseAudio Volume
Control. The left and right speaker “bars” are moving, but no audio is
coming out.
Med vennlig hilsen/Best regards
Lars-Eivind Bjørtvedt
I tried to put some headphone in the front audio jack, and that worked - so the audio was playing, just out of the wrong port.
Then I played around in alsamixer and found a setting there called “Analog out”. If i pressed the up arrow there, it would change from “Analog Output [Stereo Headphones FP]” to “Analog Output [multichannel]”, and that was it.
Still don’t know exactly what I did here, but at least I have sound now. Thanks for all help
