And this time, it’s official
Again congratulations
So , it’s official : HAPPY! HAPPY ! JOY ! JOY ! JOY !
Good job, Martin and all the team of developers!
bug to report Martin. The notifications applet in the top panel throws a wobbly every time it logs in and must be reloaded. When it reloads, the volume icon is missing. This is on the 32 bit version.
Also, keeps reporting an arror on bootup and login. cant find the log, but made a couple of screenshots of the erros:
@stevecook172001 This is a known bug and is allready reported. It was mentioned in the release notes. Please submit a bug-report using the default channels (just hit the continue button).
Cheers, will do Wiz.
Great accomplishment @Wimpyand team!
That notification tray issue is in the release notes
Running superbly on Toshiba P50 Laptop w/Nvidia 740GT graphics! Very pleased…
Could anyone say if ALL new features will be ported to 14.04 LTS release as well?
No not all, but most.
Hello
Well, after upgrade from Ubuntu Mate Alpha 2 to Beta1, I have several issues:
- Deluge doesn't work:
bobses@bobsesland:~$ deluge
** (deluge:19933): WARNING **: couldn't make the type `gio.MemoryInputStream' ready
** (deluge:19933): WARNING **: couldn't make the type `gio.MemoryOutputStream' ready
TypeError: type 'gio.MemoryOutputStream' is not dynamically allocated but its base type 'main.GPollableOutputStream' is dynamically allocated
** (deluge:19933): WARNING **: couldn't make the type `gio.unix.InputStream' ready
** (deluge:19933): WARNING **: couldn't make the type `gio.unix.OutputStream' ready
/usr/lib/python2.7/dist-packages/gtk-2.0/gtk/init.py:40: RuntimeWarning: tp_compare didn't return -1 or -2 for exception
from gtk import _gtk
ImportError: could not import gio
[ERROR ] 17:44:33 ui:168 cannot import name Widget from gtk
Traceback (most recent call last):
File "/usr/lib/python2.7/dist-packages/deluge/ui/ui.py", line 149, in init
from deluge.ui.gtkui.gtkui import GtkUI
File "/usr/lib/python2.7/dist-packages/deluge/ui/gtkui/init.py", line 1, in
from gtkui import start
File "/usr/lib/python2.7/dist-packages/deluge/ui/gtkui/gtkui.py", line 58, in
import gtk, gtk.glade
ImportError: cannot import name Widget from gtk
[ERROR ] 17:44:33 ui:169 There was an error whilst launching the request UI: gtk
[ERROR ] 17:44:33 ui:170 Look at the traceback above for more information.
2 Radiotray doesn't work too:
bobses@bobsesland:~$ radiotray
** (process:19943): WARNING **: couldn't make the type `gio.MemoryInputStream' ready
** (process:19943): WARNING **: couldn't make the type `gio.MemoryOutputStream' ready
** (process:19943): WARNING **: couldn't make the type `gio.unix.InputStream' ready
** (process:19943): WARNING **: couldn't make the type `gio.unix.OutputStream' ready
** (radiotray:19943): WARNING **: couldn't make the type `gst.Bin' ready
** (radiotray:19943): WARNING **: couldn't make the type `gst.Pipeline' ready
/usr/lib/python2.7/dist-packages/gst-0.10/gst/init.py:193: RuntimeWarning: tp_compare didn't return -1 or -2 for exception
from _gst import *
TypeError: type 'gst.Pipeline' is not dynamically allocated but its base type 'main.GstChildProxy' is dynamically allocated
I hope for a quick fix to these bugs.
Given that I don’t develop, or ship, either of the applications what do you expect me to do exactly?
@Bobses Please submit bugs to the appropriate channels. In this case you could best report these bugs to the developers of both Deluge and Radiotray.
Sorry, Wimpy. I don’t expect nothing special from you.
I know that you don’t develop, just I just submitted here that issues exists.
@wizd3m, Deluge and Radiotray worked great until today, before updates. I use Ubuntu Mate 15.04 from Alpha 2 version.
@Bobses. The bug has allready been submitted and triaged https://bugs.launchpad.net/ubuntu/+source/radiotray/+bug/1426229.
This is a bug in pyGobject (that library recieved an update) https://bugs.launchpad.net/ubuntu/+source/python2.7/+bug/1426294.
It is not that we do not want to help. I even installed radiotray to confirm the issue :). But when I tried to report the bug I got notice that it had allready been reported.
@wizd3m Thank you very much.
Ubuntu Mate is great and I’m very enthusiastic.
