I managed to convert the system to berryboot squashfs image and I can boot into it however there seems to be USB drive issue once you are running the OS. If only I could get this fixed, everything would be perfect. By the way, the error you are facing is because of the symblink within the /sbin or the /usr/lib directory. If you copy the files from /lib to /usr/lib directory, it seems to do the trick of booting the squashfs Img.
It look likes there a considerable interest in getting UbuntuMATE to work as a squashfs with berryboot. Like I said, Iāve gotten it to boot, but it just kind of hangs during the user setup on the keyboard configuration.
Hereās how I created it:
bunzip2 ubuntu-mate-15.04-desktop-armhf-raspberry-pi-2.img.bz2
sudo kpartx -av ubuntu-mate-15.04-desktop-armhf-raspberry-pi-2.img
sudo mount /dev/mapper/loop0p2 /mnt
sudo rm /mnt/sbin/init ; sudo cp -a /mnt/lib/systemd/systemd /mnt/sbin/init
sudo sed -i ās/^/dev/mmcblk/#\0/gā /mnt/etc/fstab
sudo mksquashfs /mnt ubuntu-mate-15.04-desktop-armhf-raspberry-pi-2_squashfs.img -e lib/modules
sudo umount /mnt
sudo kpartx -d ubuntu-mate-15.04-desktop-armhf-raspberry-pi-2.img
The important difference from the main berryboot instructions is the 4th line replacing the sbin/init file. Itās a link to the systemd file, and at least within the squashfs image, the raspberry pi canāt find the link. This fixes it.
Hopefully someone can get it beyond the keyboard glitch. Good luck!
I just discovered that while the keyboard configuration just spins its wheel with my berryboot squashfs image, you can hit CNTL-ALT-T to open a console window! Unfortunately, you canāt do a lot (i.e. sudo) because the user is āoemā and I canāt find its password. Anyone know it?!
For the Pi 2,the only option for MATE 1.10 will be to compile it yourself or wait for Ubuntu MATE 15.10 because the armhf support in the PPAs is a bit hit and miss
Using a HDMI eGalaxTouch type touch screen with natural resolution 1280X600
I have set up a ubuntu distro Ubuntu/Linaro, it is OK.
With the Mint 15.04, I have a problem with GUI not filling the whole screen.
It does fill the whole screen without doing anything else with Raspbian, OpenElec, and Ubuntu/Linaro,
but with yours Mint 15.04, there are huge black borders around the screen.
I tried to change the file config.txt, but all it did was change resolution inside the same size screen
with same black borders.
Can you advise how to make it expand to the whole screen as it does for other distros?
If anyone knows please contact me on G+ or email me: [email protected]
I have no experience here and so this next question may seem a little stupid to experienced users of the pi, but here goes:
Can UM on the Pi 2 browse and live-stream video effectively from sites like BBC iplayer as well as stream videos from a server over a cabled home-network? That is to say, without unacceptable levels of video/audio lag? I am asking this cos I am currently using an old Pentium D under my television for this purpose. But, it would be nice to have a neat little box strapped to the back of my TV instead. I just donāt want to get it if itās not up to the job.
Well I think getting the oem password will solve most of our problems. But changing that will be a time taking process as this image is ARM specific. I see two ways. Either the makers share the OEM account password. Or we can make our own image with known passwords. We can change passwords if we mount this image to a system running same architecture. Letās see. Will be back tomorrow. Hoping someone have solved it before me.
In a way, it is good that all this information is together for the Pi but when it doubles and triples in size will be more difficult to go through. Thatās what is wanted long-term, to have all manner of different support questions to roll up under a single thread?
Hi !
I tried Ubuntu mate on my rpi2 and itās awesome !
I saw gstreamer1.0 and a lot of plugins are available on the repository but gstreamer1.0-omx which provides hardware acceleration to decode / encode video is not.
Will it be available soon ?
I try to compile and install it from git and rapsbian Jessie .deb file from repo without success ā¦
Got it working with berryboot. Installed it on a seperate memory card and mounted the same image. This allowed me to change password for OEM account. And also to set password for root account before squashing the image. This allowed me to bypass the keyboard configuration stuckup. I finally was able to login as OEM, set up a new account and get it properly working.
Now someone help me fix this error.
Downloaded and installed on RPI2. However when I upgraded via sudo apt-get update && sudo apt-get -y upgrade && sudo apt-get -y dist-upgrade, it goes ok for about half hour and then, I get all kinds of errors without completion.
is there a special way to upgrade?
Followed exactly as they say here.
Thanks
Sorry to repeat this question, but I really need some advice from someone who already has UM installed on the Pi 2 and no-one has replied as yet. There must be surely someone here who is able to definitively answer the following:
Can UM on the Pi 2 browse and live-stream full screen video effectively from sites like BBC iplayer as well as stream videos from a server over a cabled home-network? That is to say, without unacceptable levels of video/audio lag/tearing? I am asking this cos I am currently using an old Pentium D under my television for this purpose (which is quite capable of the job, but is very bulky and visually obtrusive). But, it would be nice to have a neat little box strapped to the back of my TV instead. I just donāt want to get it if itās not up to the job. Hitherto, Iāve only had experience a Pi 1 with Rasbian on it and it was certainly not up to the job.
Excellent distro - it certainly made my Pi 2 much more usable to have proper Ubuntu, thanks!
This page has a tough time loading on Firefox on the Pi 2 - its somehow too heavy - fancy Javascript?
Besides that, is there news on GPU-accelerated rendering? There is clearly development being done on getting the VideoCore 4 working with OpenGL (http://dri.freedesktop.org/wiki/VC4/) - any plans to make that work in MATE?
Is there a way to boot into text mode/not start x? I want to use the mate image but I just donāt always want mate running. I could run sudo service lightdm stop at startup but I rather not start it at all. echo 'manual' | sudo dd of=/etc/init/lightdm.override doesnāt work.
