Ubuntu MATE 15.10 for the Raspberry Pi 2.
@Wimpy and @rohithmadhavan have made an Ubuntu MATE image for the Raspberry Pi 2 which you can download or build yourself.
The image is functional and based on the regular Ubuntu armhf base, not the new Snappy Core, which means that the installation procedure for applications is the same as that for the regular desktop version, ie using apt-get.
We have done what we can to optimise the build for the Raspberry Pi 2 and one can comfortably use applications such as LibreOffice, which in fact is a joy to use
But the microSDHC I/O throughput is a bottleneck so we recommend that you use a Class 6 or Class 10 microSDHC card. If you build the image yourself we recommend you use the f2fs
filesystem.
You'll need a microSD card which is 4GB or greater to fit the image. The file system can be resized to occupy the unallocated space of the microSD card, similar to Raspbian.
NOTE! There are no predefined user accounts. The first time you boot the Ubuntu MATE image it will run through a setup wizard where you can create your own user account and configure your regional settings. The first boot is quite slow, but once the first boot configuration is complete subsequent boots are much quicker.
Download
A pre-built image available from the Ubuntu MATE website.
Putting the image on microSDHC
Download the image and then:
- Extract the
.img.bz2archive to get the image file.
bunzip2 ubuntu-mate-15.10-desktop-armhf-raspberry-pi-2.img.bz2
- Write the image file to the microSD card as root.
sudo ddrescue -d -D --force ubuntu-mate-15.10-desktop-armhf-raspberry-pi-2.img /dev/sdX
The drive may be mounted on any /dev/sdX so use the command lsblk to
check.
Re-size file system
There are no utilities included for automatic file system re-sizing. However,
it's not hard to do manually. Once booted:
`sudo fdisk /dev/mmcblk0`
Delete the second partition (d, 2), then re-create it using the defaults
(n, p, 2, enter, enter), then write and exit (w). Reboot the system, then:
`sudo resize2fs /dev/mmcblk0p2`
Enable and Disable X11
We created a simple utility called graphical to disable/enable the MATE desktop environment for easily creating a headless "server". Executing graphical disable will present a console login on the next boot, with now X11 or associated services running. If you want to get the full Ubuntu MATE desktop back, run graphical enable and reboot.
Hardware accelerated video
Most videos will play with hardware acceleration using omxplayer which is pre-installed in Ubuntu MATE. However if you have MPEG-2 or VC-1 video video files then you will need MPEG-2 and/or VC-1 licenses from the Raspberry Pi Store.
Redirecting audio output
You can select which audio device omxplayer should output audio to.
For HDMI
omxplayer -o hdmi video.mp4
For 3.5mm audio jack
omxplayer -o local video.mp4
The sound will output to HDMI by default if both HDMI and the 3.5mm audio jack are connected. You can, however, force the system to output to a particular device using amixer.
For HDMI
sudo amixer cset numid=3 2
sudo amixer cset numid=3 1
Feedback and Improvements
Please post all feedback here, in this topic. If you have any improvements then please submit a pull request to our
BitBucket.
Credits
- Rohith Madhavan - Made the Ubuntu MATE 15.04 image.
- Martin Wimpress - Added first boot setup wizard and architecture optimisations.
- Ryan Finnie - Raspberry Pi 2 Kernel, Firmware and video driver packages.
- Sjoerd Simons - Made the initial Raspberry Pi 2 kernel patches for Debian Jessie.
Sergio Conde - Maintains
omxplayerfor the Raspberry Pi. - Spindle - a tool to help spin distribution images
Changes
2015-10-22 - Ubuntu MATE 15.10 for Raspbery Pi 2 Final Release
- Added OMXPlayer GUI.
- Added YouTube Downloader.
- Added
fake-hwclock. - Added
python-spidevandpython3-spidev. - Added
python-codebug-tetherandpython3-codebug-tether. - Added
python-codebug-i2c-tetherandpython3-codebug-i2c-tether. - Added file system integrity checking on first boot.
- Optimised first run of MATE Menu.
- Optimised LibreOffice icons.
- Reinstated
oem-config, which has been patched for the Raspberry Pi 2.- Now includes the Ubuntu MATE slideshow.
- Fixed udev rules and groups for accessing
spi. - Fixed Scratch, it now runs via a
sudowrapper.- Simliar to how Raspbian does it except only Scratch can be executed with elevated privileges, not everything.
- Removed Compiz.
2015-10-14 - Ubuntu MATE 15.10 for Raspbery Pi 2 Release Candidate
- Fixed framebuffer so it now uses 32-bit colour depth.
- Added Minecraft Pi Edition 0.1.1-4.
- Added Scratch 20150916.
- Added Sonic Pi 2.7.0-1.
- Added essential Python 2.7.x and Python 3.4.x libraries.
- Added
raspi-gpio. - Added
python-rpi.gpioandpython3-rpi.gpio. - Added
python-serialandpython3-serial. - Added
python-picameraandpython3-picamera. - Added
python-sense-hatandpython3-sense-hat. - Added
python-astropiandpython3-astropi. - Added
python-pygameandpython3-pygame. - Added
udevrules forgpio,input,i2c,spi,vchiq. - Added
/usr/local/sbin/adduser.localhook to automatically add new users to theadm,gpio,i2c,input,spiandvideogroups. - Added
openssh-serverwith first-boot host key regeneration. - Added
graphicala utility to disable/enable the MATE desktop environment for easily creating a headless "server". - Updated to Linux 4.1.10.
- Now using the kernel, firmware and drivers from Raspberry Pi Foundation and includes
rpi-updateto easily update the kernel and firmware.
- Updated
/boot/config.txtso it is now fully documented. - Updated to
raspi-copies-and-fills(high performance memcpy and memset) 0.5-1. - Updated to
xserver-xorg-video-fbturbo(an accelerated x.org driver) 0~git.20151007.f9a6ed7. - Updated to
omx-player0.3.6~git20150912~d99bd86. - Updated
/boot/config.txtso when HDMI is connected audio is sent over HDMI by default. - Enabled Plymouth to improve startup and shutdown performance.
- Removed
oem-config.
2015-04-22 - Ubuntu MATE 15.04 for Raspberry Pi 2 Final Release
- Enabled Ryan Finnie's PPA.
- https://launchpad.net/~fo0bar/+archive/ubuntu/rpi2
- Many thanks to Ryan for adding Vivid as a build target.
- Changed from
cfqtodeadlineI/O scheduler. - Added
xserver-xorg-video-fbturbo(an accelerated x.org driver) 0~git.20150305.e094e3c-1.15.04.- Limited to hardware accelerated window moving and scrolling.
- Added
raspi-copies-and-fills(high performance memcpy and memset) 0.4-1. - Added
oem-configso first boot provides a setup wizard. - Added
rpi2-ubuntu-erratafor facilitating post-release updates/migrations. - Added sym-links to VideoCore utilties in
/opt/vc/for 3rd party script compatibility. - Added
f2fssupport to the build script.- Pre-built images available for download use
ext4becausef2fsfile systems can not be resized
at present.
- Updated to Linux 3.18.0-20.21.
- Updated to
flash-kernel3.0~rc.4ubuntu54+rpi2.4. - Updated to
omxplayer0.3.6~git20150402~74aac37. - Updated to
raspberrypi-firmware-nokernel1.20150402.3ea439c-1. - Updated to
raspberrypi-vc(VideoCore GPU libraries) 1.20150323.7650bcb-1. - Fixed
/etc/network/interfacesso that the Ethernet device is now configurable via Network Manager. - Removed
openssh-serveruntil host key regeneration can be integrated.
2015-03-14 - Ubuntu MATE 15.04 for Raspberry Pi 2 Beta 2
- Enabled
systemdas the init system. - Added
raspberrypi-vc(VideoCore GPU libraries) 1.20150301.0de0b20-3. - Added
omxplayer0.3.6~git20150217~5337be8. - Added
linux-firmware. - Added
openssh-server.
2015-03-07 - Ubuntu MATE 15.04 for Raspberry Pi 2 Beta 1
- Initial Release.
TODO
- Add automatic reszing of the root file system.
- Add
raspi-configor equivilent.
