Replies to this topic will appear as comments at the bottom of this blog post.
Originally posted by Karan Jadhav (disqus_eMKa2vCOYG) on 2017-09-28
Is it fit in 8GB SD card for pi3 ???
Is it fit in 8GB SD card for pi3 ??? https://uploads.disquscdn.c...
Originally posted by Grosged (grosged) on 2017-10-12
Yes, it's possible to use an 8gb sd card as the Ubuntu MATE image size is 5gb ;)
Originally posted by Thierry Mistert (thierrymistert) on 2017-11-23
Hello,
I'm working with RasPi3 Mod B.
i have a "Failed to load Kernel Modules" error at each boot startup ??
Is it normal ?
Else, have you an idea to correct it.
Thanks
Error à supprimer
Originally posted by curt (disqus_CbjIhhDBvE) on 2018-02-24
same
-everything works great however. -Amazingly using blender software now as well !
Edit the file: /etc/modules-load.d/cups-filters.conf
Make it look like this:
# Parallel printer driver modules loading for cups
# LOAD_LP_MODULE was 'yes' in /etc/default/cups
#lp
#ppdev
#parport_pc
Also, edit the file: /etc/default/cups
# do not load parallel port modules
LOAD_LP_MODULES="no"
Reboot your system, and the errors should be suppressed.
Originally posted by Andrei Krasutski (andreikrasutski) on 2018-04-18
Ubuntu MATE 16.04.2 does not work for Raspberry Pi 3 Model B+ 2018. Rainbow screen / Coloured screen problem!
