Originally posted by matale0 (Xa0s) on 2016-04-30
is that on already ? out yet ?
Originally posted by Baz_Man_03 (baz_man_03) on 2016-05-01
how do u upgrade easily from 15.10, possibly using terminal?
sudo do-release-upgrade -d
Originally posted by Javier (disqus_KVUZO1xSU5) on 2016-05-09
What version of PHP does it ships with?
Originally posted by Samuel S. Mandal (samuel_s_mandal) on 2016-05-09
Anyone running Killer 1535 wifi on this thing?
Originally posted by Antonio (disqus_vY9GBod0B3) on 2016-05-22
I cant either its an issue with the kernel not loading the firmware :-( and im too noob to know how to fix it to be honest
Anyone knows how to fix this ?
Originally posted by Jeff Haynes (disqus_LhRrzm1V4R) on 2016-06-02
Hi - I installed 16.04 LTS over 14.04 LTS with no issues and I wanted to install MATE over this. So I ran the following in terminal
sudo apt-add-repository ppa:ubuntu-mate-dev/ppa
sudo apt-add-repository ppa:ubuntu-mate-dev/utopic-mate
sudo apt-get update
sudo apt-get install mate-desktop-environment-core
However after restart - nothing changed! I still have the 16.04 LTS version. Any ideas what to do next?
Thanks
Jeff
Originally posted by Giosia Gentile (giosiagentile) on 2016-06-13
Hi, I do an upgrade form 15.10 to 16.04 but now I don't have the MATE desktop enviorment. Can you help me? Thanks
Originally posted by Márcio Santana (disqus_KCsVRQ2eZl) on 2016-06-26
Now finally stable as the sound of the problem amd hdmi. I will use until 2019 now!
Originally posted by Kevin Mitnick (disqus_LtqU2tLnQ1) on 2016-08-12
I can't login while live using.
what is the default root user password of ubuntu mate?
Originally posted by Claudio Cisty (claudiocisty) on 2016-09-07
I installed Ubuntu Mate and I can't write capital a on keyboard when I press Shift+a, any idea why?
Originally posted by Heinrich du Plooy (heinrichduplooy) on 2016-09-16
My broadband device, inserted into my Rasperry Pi 3 which is my home
wi-fi router, kept on disconnecting after about 20 minutes. I started
to investigate...
In log file /var/log/syslog of ubuntu mate 16.04 for raspberry pi 3 the
following error kept popping up:
“….rsyslogd-2007:
action 'action 17' suspended, next retry...“,
This error kept on filling up my syslog logfile. A sollution was
found through my friend google, I commented out the following lines
at /etc/rsyslog,d/50-default.conf
#daemon.*;mail.*;\
#news.err;\
#*.=debug;*.=info;\
#*.=notice;*.=warn |/dev/xconsole
The other service you also should consider to remove is :
sudo apt-get purge brltty
which also clutter the syslog file,
I created a file, alive.sh that retrieves an image from a weather site every 20 minutes, which is run from crontab, which keeps my link to the internet via the mobile broadband modem alive:
#!/bin/bash
wget http://www.1stweather.com/m...
sleep 5
date >> /var/log/alive.log # creates an entry in a log file to monitor the script
rm -rf AVN* # deletes the gif file
exit
After I did these adjustments my Ubuntu mate 16.04 for raspberry pi stay connected to the internet with my Mobile Broadband device.
Any other suggestions to keep my mobile broadband divice active would be appreciated.
Originally posted by Shane (disqus_tINSq8yr9g) on 2017-04-10
Everything works fine here! Great work guys!!!
Originally posted by Micah Tolbert (micahtolbert) on 2017-04-18
whats the best vnc to use to remote into the pi 3 running ubuntu mate 16.04 from a windows? i tried realvnc but it says unable to locate package
Originally posted by Jonid Mesareja (jonidmesareja) on 2017-07-10
Works great, easy, beautiful. Simple the best Ubunte ever so far. Downloading and seeding... :)
Originally posted by The-ePoch (epoch10e43) on 2018-01-14
How can I get the original 16.04 and not later updates (16.04.3). My R9 290 will not work with amdgpu-pro drivers beyond the original 16.04. All other versions are incompatible.
Originally posted by Helder Pereira (disqus_k0Kma31VFS) on 2018-02-18
It is really a very good distro. Complet, clean, stabil, run fine in old and new computers. It's simple but very well organised. Have everything and support for everything that a end user need. Congratulations and Thanks to all.
Originally posted by Ali Erdengiz (alierdengiz) on 2018-03-20
Well, I downloaded the image and it works great with the Raspberry Pi 3B. However, it doesn't boot with the new Raspberry Pi 3 B+. I hope this will be resolved quickly, because the new Rpi 3B+ has 802.11ac which I desperately need as I have serious WiFi problems in 2.4GHz. I tested the B+ with 802.11ac running debian and it was heaven.
Originally posted by Will (disqus_u9n4sjKnPO) on 2018-04-07
Is Ubuntu Mate16.04 LTS supported by Dell PowerEdge T630 server? Whether I need to install additional drivers or not?
Originally posted by Sunwind (disqus_xXQOXQjYuB) on 2018-04-14
Is Mate going to be updated for the new RPi 3B+? It won't run on it.
