I have Ubuntu MATE 16.10/Compiz/Cupertino on a Dell Dimension 9150. It was hanging (keyboard and mouse unresponsive, if sound is playing it goes into a one second loop) * about once a day, now once a week. I have done a memory check, replaced the memory, and reseated the CPU heatsink in case it was overheating. In the BIOS I have tried setting Speedstep on and off. I update Ubuntu MATE daily.
Is it likely to be a hardware or software problem? (I have read on another thread that if the caps lock still switches the LED on/off it isn’t a hardware problem, but I suspect that is just done within the keyboard so I’m disinclined to believe it.) What can I run or check to identify the cause?
*Edit: I’ve since remembered that Thunderbird rather more frequently seizes up briefly (no mouse input), this clears after a minute or two.
