I have trouble with connection of external WD 320 GB HD through Firewire port located on my notebook. The disc is recognized on Ubuntu MATE 17.04 but it can not mount it. Drive’s LED flashes during procedure. External case where disc is located have also USB port and that connection works fine. The trouble is within the Firewire.
Here are the output of following commands:
lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 119,2G 0 disk
└─sda1 8:1 0 112,7G 0 part /
sdb 8:16 0 298,1G 0 rbc
sr0 11:0 1 1024M 0 rom
sudo lshw | less:
*-scsi:2
physical id: 3
logical name: scsi6
*-disk
description: Windows FAT volume
product: 00BEVE-00A0HT0
vendor: mkfs.fat
physical id: 0.0.0
bus info: scsi@6:0.0.0
logical name: /dev/sdb
version: FAT32
serial: 17ec-df48
capacity: 298GiB
capabilities: fat initialized
configuration: FATs=2 ansiversion=4 filesystem=fat label=WD320FW logicalsectorsize=512 sectorsize=512
sudo fdisk -l:
Disk /dev/sdb: 298,1 GiB, 320072933376 bytes, 625142448 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
lsmod|grep firewire:
firewire_sbp2 24576 0
firewire_ohci 40960 0
firewire_core 65536 2 firewire_sbp2,firewire_ohci
crc_itu_t 16384 1 firewire_core
dmesg|grep 1394:
[ 5.681394] snd_hda_codec_analog hdaudioC0D0: Line=0x9
[ 9.198521] scsi host6: SBP-2 IEEE-1394
[ 37.640224] scsi host6: SBP-2 IEEE-1394
dmesg|grep sbp:
[ 9.198590] firewire_sbp2 fw1.0: workarounds 0x20 (firmware_revision 0x012804, model_id 0x000001)
[ 11.486748] firewire_sbp2 fw1.0: logged in to LUN 0000 (0 retries)
[ 36.184118] firewire_sbp2 fw1.0: released target 6:0:0
[ 37.640360] firewire_sbp2 fw1.0: workarounds 0x20 (firmware_revision 0x012804, model_id 0x000001)
[ 38.200707] firewire_sbp2 fw1.0: logged in to LUN 0000 (0 retries)
Disc can be even test with hdparm:
sudo hdparm -Tt /dev/sdb:
/dev/sdb:
Timing cached reads: 12398 MB in 1.99 seconds = 6227.68 MB/sec
Timing buffered disk reads: 112 MB in 3.01 seconds = 37.20 MB/sec
tail -f /var/log/syslog:
scsi 6:0:0:0: Direct-Access-RBC WDC WD32 00BEVE-00A0HT0 PQ: 0 ANSI: 4
sd 6:0:0:0: Attached scsi generic sg2 type 14
sd 6:0:0:0: [sdb] 625142448 512-byte logical blocks: (320 GB/298 GiB)
sd 6:0:0:0: [sdb] Write Protect is off
sd 6:0:0:0: [sdb] Mode Sense: 11 00 00 00
sd 6:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
sd 6:0:0:0: [sdb] Attached SCSI disk
I was searching through web to find some solutions and the closes were post from 2012 mentioned that there can be trouble with firmware_revision 0x012804.
https://ubuntuforums.org/showthread.php?t=1157686
and
http://marc.info/?t=132975440900001
If I chmod a-x /lib/udev/scsi_id then the disc is recognized in Caja but it still can not be mounted ( wrong fs …)
May be you can give me any ideas…
Thank you
