I think I found a solution to my “Hibernate / Resume from Hibernate” issue for Ubuntu (MATE) 18.04, but still testing… I’m so really excited , I could hug the entire world
The “magic” happened by setting the additional kernel parameter resume=UUID=UUID_OF_SWAP_PARTITION via Grub Customizer or via: sudo pluma /etc/default/grub
and adding the “resume” parameter to this line GRUB_CMDLINE_LINUX_DEFAULT="quiet splash resume=UUID=UUID_OF_SWAP_PARTITION"
The special “resume” kernel parameter was not required for Ubuntu 16.10, 17.04, 17.10 ! Why is it required now ? Anyway, it doesn’t matter, as long as there is a way to make this work
I’ll be back with a detailed instruction set for Hibernate / Resume from Hibernate for Ubuntu (MATE) 18.04 (of course, my way).
Once again, thank you so much to the wonderful people making Ubuntu MATE such a lovely DE for my PCs.
Only for clarification:
The suspend option, is the same as Windows’s sleep right? The machine goes to a low-power state and the current working state is stored… HIbernate powers down the PC completely but the current working state is stored on the hard drive…
Am I right?
I’m a very new (or is that gnu) user of Linux. Figured if my musician son can figure it out so can I. Picked up a usb live product from osdisc.com and had win 10 do a full gainer out the window! Felt good. U-Mate is fast stable and easy to install & use. The LibreOffice Suite is Sweet and I’m having fun at the keyboard again.
Excellent job, Wimpy !
Now the Panel has contracted the habit of forgetting the locations of items in it. It does not happen regularly. Intermittently it will rearrange application launchers between reboots. Or, it will move applets that have ‘Locked To Panel’ checked! So, I have to unlock them all, rearrange them, and then lock them again. Endless drama!
I wanted to thank all devs and Martin in particular for all the work they put into UM. I love the product and it’s great to be Windowsfree. Posting this hier for visibility after reading a few peculiar posts in other sections of the forum. Thanks again.
Thanks a lot for this stable version! I just switched this weekend from windows 10 to Ubuntu MATE. In the past I experienced some problems with the transition to Linux but with Ubuntu MATE everything works excellent out of the box! Great job!
Yesterday I did upgrade my Ubuntu 16.04 to Bionic Beaver 18.04 , it says I have missing DPKG files , now I lost internet connection on Ubuntu Mate , server not found error , and no log in to Bionic Beaver , it prompts me to log in over and over again . I want to use Ubuntu mate 18.04 , what can I do ? Help please
Not a lot, from the view point of someone who is installing Ubuntu for a few years now. But quite a bit if you are „just a user“. One Maschine was as lenovo Legion y520 and there you need to tweak the bios a bit to make sure UM „sees“ the drives and some lines in the terminal to get WiFi going.
It’s all not rocket science and it ran like a charm afterwards. But most people wouldn’t even try that sort of stuff.
Why would they make the process to install 18.04, such a pain in the ass? You can only “upgrade” from a couple other distros. If you’re not currently running one of those, you have your work cut out for you. And why so many distros? This Linux thing is going in too many diverging directions.
